HELP!! Error Code P0344 Cam POS Sensor..
Old May 2, 2005 | 09:59 PM
oggjay's Avatar
oggjay
Going about 50+ MPH.. the truck starts to shutter... Almost like its shutting down.. My 2000 F350 SD Diesel keeps throwing this code... "Camshaft Position Sensor Circuit Intermittent" .. P0344
What exactly does this mean.. How do I fix it.. Has it happened to anyone else...????????
Thanks in advance.. Jay
Old May 2, 2005 | 10:03 PM
Pocket's Avatar
Pocket
Lucky you are getting a code, most trucks just die suddenly without warning. It's an easy fix. You can go to the article here on this site that shows you how to replace it. The part can be purchased at you local Ford dealer, or you can get it much cheaper at an International dealer if you have one close to you.
Old May 2, 2005 | 10:05 PM
whalerron's Avatar
whalerron
There is an write-up here in the Technical Articles section and it describes the replacement of this part. It's a common failure but the part is easy to replace.
https://www.ford-trucks.com/article/...ke_Diesel.html
Old May 2, 2005 | 10:35 PM
oggjay's Avatar
oggjay
Everyone on this site is awesome... Everytime I have an issue its easily resolved..
Thanks again..
Anyone have an Idea of what that part cost.?? $$$$
Old May 2, 2005 | 10:38 PM
oggjay's Avatar
oggjay
I just went out and looked.. Is it the sensor just above the Crankshaft pulley...??
Above to the left.??
Old May 3, 2005 | 04:19 AM
'96 F-250's Avatar
'96 F-250
Yup, you're right on!
Old May 3, 2005 | 07:30 PM
oggjay's Avatar
oggjay
I put the new sensor in today but now its leaking oil there.. I know I cleaned the surfaces and used new oil when installing it.. Will it hurt to take it back out and use some RTV.. ??
Domino
Jul 18, 2015 08:38 PM
jamull2852
Sep 8, 2013 08:59 AM
jamull2852
Modular V8 (4.6L, 5.4L)
Sep 2, 2013 04:25 AM
mcboudreaux
Jul 12, 2012 11:23 PM
westcoastslider
Dec 7, 2011 02:10 PM
