Whats throwing these codes?
Old Dec 6, 2011 | 05:39 PM
westcoastslider's Avatar
westcoastslider
P0344 CMP sensor circuit intermittent
P0236 Turbo boost sensor circuit A performance
No CEL but my scanguage pulled these codes.
Old Dec 6, 2011 | 07:06 PM
fordpride's Avatar
fordpride
P3044 is the cam shaft sensor
P0236 MAP Turbo boost sensor A ckt performance Uses Inferred MAP signal Restricted inlet/exhaust/supply hose, missing hose
Old Dec 6, 2011 | 08:06 PM
Hussler's Avatar
Hussler
From this site ... 97-15A 7.3L DI Turbo Workshop Manual
0236 = Detected high boost signal at low idle. (Restricted MAP line.) (Inrange Fault).
0344 = Incorrect number of sync to transition counts detected, possible intermittent CMP sensor/circuit fault
If no CEL now then clear codes .. probably old ones.
Old Dec 7, 2011 | 02:59 AM
stainlessstroker95's Avatar
stainlessstroker95
Where is this supply tube located? I have got that code befor also. I think that this hose is pluged and not letting my ebpv operate. Is that possible?
Old Dec 7, 2011 | 03:10 AM
Copedawg's Avatar
Copedawg
X2 on what Jim said. Clear em and try to read again next week.
Old Dec 7, 2011 | 03:13 AM
BuckHammer's Avatar
BuckHammer
I had a P0236 once. I cleared the codes and it never returned.
Old Dec 7, 2011 | 09:49 AM
westcoastslider
I'm thinking the P0236 is a restricted exhaust supply hose. Watching my exhaust back pressure the gauge is slow to response to what the truck is actually doing. I think I'll pull and clean the metal line going to the sensor.
The truck has completely died all at once a few times making me think the cps may have thrown the P0344.
Thanks for the help guys. I'll fix these couple of things and clear the codes.
Old Dec 7, 2011 | 09:53 AM
westcoastslider
Yes. I think thats whats happening to me. It's very common on these rigs. It's the small steal line that runs up the front of the motor on the pass side to the exhaust pressure sensor. Gets all plugged up with carbon or rusts in half.
Old Dec 7, 2011 | 01:46 PM
stainlessstroker95
Ok thanks. I think i found the line. It is the one that goes from the exhaust manifold to a sensor that mounts on a bracket on top of the hpop. Is this correct?
Old Dec 7, 2011 | 01:49 PM
DIYMechanic's Avatar
DIYMechanic
That's the one! I was able to clean mine out with some compressed air, brake cleaner, and a piece of 1/8 aircraft cable in the chuck of my cordless drill. Just be sure you run the drill in the right direction or it will just take the twist out of the cable and you won't get anywhere.
Old Dec 7, 2011 | 02:10 PM
stainlessstroker95
Thanks nate I will try that. Hopefully it will let my ebpv to start working.
BradSmith-7.3L
Feb 16, 2016 07:12 PM
High Intentions
Apr 6, 2009 08:01 AM
mollikate
Feb 6, 2008 01:36 PM
hedhntr
Sep 10, 2007 01:31 PM
krzyk26
Jul 1, 2004 04:41 PM
