Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
First Issue
Old May 1, 2005 | 10:00 AM
Nitramjr's Avatar
Nitramjr
First Issue
Well, it took a month but I have a problem with the '05 Escape. Although if this is as bad as it gets I am lucky.
I went to play the CD player this morning (basic model 6 CD changer, not the audiophile thingy) and it wouldn't play any of the 6 CD's in the player. It spit them out one at a time while displaying "CHECK CD". These are all commercial CD's, not copies. They have all played in there before today.
Any ideas? Has anyone ever taken a vehicle back to Ford for a radio issue under the warranty? How were they? Is this just the car gods telling me to get rid of the stock unit? I hate to be picky over something minor but......
Thanks.
Ray
Old Jul 31, 2005 | 03:33 PM
gdawg1881's Avatar
gdawg1881
Yes. My bro had this same problem. He had two replaced under warrenty. He just took it back to the dealer and they fixed it. That is the problem he had. How old is the car? My brother hated to lose his 6 disc for an aftermarket single.
Hope this helps.
Old Aug 3, 2005 | 09:50 AM
D2EBMA's Avatar
D2EBMA
I've had to bring several head units back under warranty. Ford doesn't do the repairs themselves - they have a vendor whose only job is to refurb the head units. It's likely that they will pull yours out, and in a week or two, replace it with a refurbed one. Hopefully you'll be luckier than I was - the head unit I got as a replacement was also bad, as was the one that replaced that! Fourth one worked like a charm, tho.
Old Aug 5, 2005 | 02:09 PM
Nitramjr's Avatar
Nitramjr
I solved the problem myself - I swapped the P.O.S. unit with the one in my '04 Escape (liked it better anyway) and then traded in the '04. Only problem is the '06 Hybrid has the same type as the '05 had. So far no problems though.
Old Aug 18, 2005 | 09:24 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
it's a junk design... I've replaced DOZENS (if not over 100)....
we pull them out, get part#, reinstall... when new one comes in swap it out... and if cd's are stuck inside it the rebuilder will mail the cd's back to us and we give them back to you.
Apparently there are some updated internal parts that they use when the fix them, so the "new" units won't have the same problem.
good luck!
Old Aug 18, 2005 | 09:42 PM
Nitramjr's Avatar
Nitramjr
Thanks for that information.
Obviously you work on these regularly so maybe you would be able to tell me what models are interchangeable? Say I went on ebay or somewhere, what model and years stereo/CD would I be able to pick up and drop right in without ANY modifications? I am looking for one to put in my '06 Escape Hybrid.
Thanks
Ray
Old Aug 19, 2005 | 06:32 PM
MazdaRangerGuy
Well I can't tell you exactly if the pinouts are the same, but almost all of the ford radios i've pulled have identical connectors... and as far as i know there is no "Security" feature built into the ford radio... so as long as the dimensions are the same I think they are all pretty much interchangable... from 98 or so up. But don't hold me liable
Good luck
Old Aug 19, 2005 | 07:25 PM
Nitramjr's Avatar
Nitramjr
Never....as far as I am concerned, all posts are followed "in my opinion" or "to the best of my knowledge" whether the poster says that or not. Unless the post is by Popa Tim or Fefarms - them dudes are pretty sharp......in my opinion.
malanr
1983 - 2012 Ranger & B-Series
Feb 21, 2010 01:44 PM
elsnowbaby
Nov 17, 2006 07:32 AM
glemon
Feb 27, 2006 10:13 PM
Dazz
2004 - 2008 F150
Aug 8, 2005 09:48 AM
primegen
Mar 25, 2002 12:54 PM
