I have a 96 explorer with a factory issued 6 CD player. The magazine is stuck inside the CD player and won't come out, any ideas how to get it out without causing damage?
>ideas how to get it
To eject the 6 pack cartrige, get a pretty sturdy piece of card board, not too thick (something like the back of a note book) and cut it about 2 to 3 inches wide and 6-8 inches long. and slide it under the bottom of the cartrige, pushing downward.
there is a trigger that releases the cartridge.
this should work even if there is no power to the unit. good luck
Another thing you could try is to find the very small reset button on the changer itself. Press this button while the changer has power. Then turn power off, and back on again and you should be able to eject your magazine.
My cartridge was stuck, I did a search on Google, and found this page. This technique of using something slim to trigger the release works great. I used a thin metal ruler that I had, but as the release is a small plastic piece, cardboard would have been fine. The release is roughly in the middle of the cartridge, on the bottom (or nearer to the driver) of the cartridge.
Regarding the reset button mentioned below, I never saw it and also don't know if that would have worked, since my cartridge was mechanically stuck and needed to have the cartridge manually triggered.
Thanks a TON for the anonymous help from over one year ago!!!
I have a 97 F-150 and have had numerous time when the cassette would get stuck in the changer. I have taken care of this by holding down the eject button and repeatedly pushing on the cassette it's self.
