Sorry, but that logic doesn't quite hold. If we were talking about direct torque like using a cheater bar on a rusty bolt then it would, but this is all torsional. For every length of steel in inches, the steel can torsionally deflect a given amount before shattering based upon several factors such as material and hardening techniques.
I don't have the equation in front of me, but the amount of torsional twist is directly proportional to the length of the shaft. Lets say a given sample of steel can torsionally deflect .1" for every inch of length. One inch will twist .1" and then shatter, while two inches will twist .2" before shattering and so on.
All things being equal, the short side shaft will always reach it's failure point before the long shaft.
And you're right, the short side DOES see less force, but can take less before failure. While the longside sees more, it is proportionally less when compared to the torsional yield of the shaft.
I told you it was a **** poor explanation, but the bottem line was still true: the short side sees less force, and is less likely to break than the long shaft. Although I understand where your math is coming from, it doesn't apply to making the long side the proper choice when locking only one side in. Lots of theories looks good on paper but don't play out in real situations.
Hey guys thanks for all the input! I'm LMAO at some of the comments, but i do think it would be a good idea to see if they make a MiniSpool for the dana 60 first,.
P.S Theres no reason to sweat over the axles guys, cuz when it breaks, it breaks! and untill then we is havin FFUUUUUUNNNNNN!!!
What is it with you standing up for the stubby, anyways?
seth is right(seth is a shaft expert), my buddy ran a welded D44 for a long time, and with both hubs, he could snap long shafts at will, but never once a short shaft...
