Offroad & 4x4
Mini spool
Old May 2, 2005 | 08:19 PM
mustange70's Avatar
mustange70
But i think that you nailed it pretty good though pro .
Old May 2, 2005 | 09:56 PM
hoxiii's Avatar
hoxiii
Sorry, but that logic doesn't quite hold. If we were talking about direct torque like using a cheater bar on a rusty bolt then it would, but this is all torsional. For every length of steel in inches, the steel can torsionally deflect a given amount before shattering based upon several factors such as material and hardening techniques.
I don't have the equation in front of me, but the amount of torsional twist is directly proportional to the length of the shaft. Lets say a given sample of steel can torsionally deflect .1" for every inch of length. One inch will twist .1" and then shatter, while two inches will twist .2" before shattering and so on.
All things being equal, the short side shaft will always reach it's failure point before the long shaft.
And you're right, the short side DOES see less force, but can take less before failure. While the longside sees more, it is proportionally less when compared to the torsional yield of the shaft.
Justin
Old May 2, 2005 | 10:33 PM
proeliator's Avatar
proeliator
I told you it was a **** poor explanation, but the bottem line was still true: the short side sees less force, and is less likely to break than the long shaft. Although I understand where your math is coming from, it doesn't apply to making the long side the proper choice when locking only one side in. Lots of theories looks good on paper but don't play out in real situations.
Old May 3, 2005 | 10:05 AM
DW2455's Avatar
DW2455
Hey guys thanks for all the input! I'm LMAO at some of the comments, but i do think it would be a good idea to see if they make a MiniSpool for the dana 60 first,.
P.S Theres no reason to sweat over the axles guys, cuz when it breaks, it breaks! and untill then we is havin FFUUUUUUNNNNNN!!!
Old Jul 2, 2005 | 12:37 PM
crack's Avatar
crack
well, when you break axels Isn't it the long shaft more often then not that breaks?
Old Jul 2, 2005 | 05:15 PM
74fordtruck's Avatar
74fordtruck
What is it with you standing up for the stubby, anyways?
Old Jul 5, 2005 | 09:01 PM
Stroker_Deezel's Avatar
Stroker_Deezel
seth is right(seth is a shaft expert), my buddy ran a welded D44 for a long time, and with both hubs, he could snap long shafts at will, but never once a short shaft...
Old Jul 6, 2005 | 03:05 PM
Thomsen's Avatar
Thomsen
Hey i'm no shaft expert LOL...but pro might be
Old Jul 6, 2005 | 03:20 PM
proeliator's Avatar
proeliator
I'm just looking out for you "little" guys
Well, thats the word around the block with the ladies
Yet another tech thread right down the toilet.........
Four.on.the.floor
May 15, 2015 02:19 PM
63' f100
Offroad & 4x4
Jun 23, 2010 01:44 PM
motorhead_83
Sep 8, 2004 03:01 PM
tankcom1
Nov 14, 2003 01:26 PM
AZ4x4f150
Offroad & 4x4
Mar 15, 2002 10:44 PM
