Offroad & 4x4
Mini spool
Old Apr 30, 2005 | 06:41 PM
DW2455's Avatar
DW2455
Mini spool
Hi, guys, does anyone have or run a mini spool in the front axle of ther 4X4?
I know its real hard on the axles and tires in the rear end especialy when on highway, But i have dana 60 mono beam front axle, its only ever used off road or in ice and snow, unlike the rear end, the front tires turn together which should eliminate the binding effect that a rear end has, so does anyone foresee any reason i couldnt run a mini spool in the front axle?? Thnx DW
Old Apr 30, 2005 | 07:12 PM
mustange70's Avatar
mustange70
My questions with this is can you get a mini spool for a 35spline 60? You can get a spool, but i'm wondering if you can get a mini spool.
Old Apr 30, 2005 | 07:28 PM
JerseysBest's Avatar
JerseysBest
If you have manual locking hubs, could you run a spool and just lock one of the hubs in case you needed to drive on pavement? Forgive the ignorance here...
Old Apr 30, 2005 | 09:23 PM
Momudder720's Avatar
Momudder720
That what most folks that run spools do. Some actually wheel with only 1 locked in (PS), then if needed, they just jump out and lock the DS in and jump right back in.
I also question your mini-spool-ness for a 35 spline 60. I know they do full spools, but I didn't know about mini's. If you're gonna go mini-spool, just lincoln-lock it til it breaks, then toss a full spool in there.
Old May 1, 2005 | 12:55 AM
fishmanndotcom's Avatar
fishmanndotcom
i welded my front and rear and i love it. back before i did my hydro assist i only locked one hub in so i could turn and then i would lock the other in when i got to the deep stuff. now i can turn easily with one finger even with both hubs locked.
-cutts-
Old May 1, 2005 | 12:21 PM
Saurian's Avatar
Saurian
Was it KO or Jopey who commented on the massive stress you're causing on the one axleshaft that is locked? I can't remember, I think he said that if you're gonna run with one hub locked then you should lock the drivers side? Reason being the shorter shaft, I think.
Maybe one of them can comment, can't remember which one it was.
Old May 1, 2005 | 06:56 PM
fishmanndotcom
very true, a good point to shed light on! also then you can make your passenger get out and lock it in!
-cutts-
Old May 1, 2005 | 10:57 PM
proeliator's Avatar
proeliator
This is why this is a poor method of going about it. But, it is safe money to lock the short side if your gonna do it.
Old May 2, 2005 | 02:23 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
you gotta do wut ya gotta do when ure poor
Old May 2, 2005 | 02:32 PM
fishmanndotcom
hell yea thats true! although it may be the poor way to do it, it sure works better than having an open front! i'd do it all day long before i bought a locker.
-cutts-
Old May 2, 2005 | 04:15 PM
proeliator's Avatar
proeliator
You guys both need to start selling plasma and just put an arb up front already
Old May 2, 2005 | 05:03 PM
KubotaOrange76
i already have to do that to support my sheep/crack habit
Old May 2, 2005 | 05:32 PM
Saurian's Avatar
Saurian
They just take the blood for free around here. I don't even know why I bother.
Old May 2, 2005 | 06:59 PM
hoxiii's Avatar
hoxiii
Question:
Wouldn't it be better to lock in the long shaft than the short shaft? Steel has a certain give per inch before it breaks. The long shaft has more inches that takes the same amount of stress per inch to break, so shouldn't the longer shaft be able to take proportionally more stress than the short shaft based on their lengths?
Justin
Old May 2, 2005 | 07:21 PM
proeliator's Avatar
proeliator
Leverage. Given the diameters are the same, the longer the shaft the more tortional forces it sees, thus, locking in the short shaft is a safer bet.
Okay, thats a crappy and probably inaccurate description of what happens, but the point is, the short side sees less force
