Towing at Altitude
Old Apr 26, 2005 | 03:08 PM
yz250roost's Avatar
yz250roost
Towing at Altitude
Hey guys,
I wasn't sure if I should post this is my home forum (73-79) or here, so I'll try here first. I've got a 75 F250 with 350 rear suspension. It has a 460 in it without smog (I'm excempt from now on...hooray!!!) My question is regarding altitude towing. I just got the truck and have yet to tow it any long distances. In about 5 weeks we are leaving to go to the Sierra Nevadas, our trip begins at 3000 feet and ends at about 8-9000 feet. I was told that my trucks performance will decrease as I climb higher. Since I don't have all the fancy fuel delivery altering computer stuff in my truck , is there any other way to combat this besides carrying extra jets. Any information is greatly appreciated.
Jeff
Old Apr 27, 2005 | 11:09 AM
mike415's Avatar
mike415
Yes, get better gearing for the rearend, carry a few clothes pins for the gas line
so you don't vapor lock, and watch your temp, that 3.5 really cuts into your
towing ability, 4:10 would be much better, forget the jets, you could set the floats
down about 1/16", that will stop some of the richness your going to have.
Old Apr 28, 2005 | 09:37 AM
pknute's Avatar
pknute
When I hauled a 10,000 lb trailer loaded with oak firewood - usually three cords - my 1980 F-350 4X4 400 auto 4.10 rear pulled the load with no difficulty once a monster tree downing skid towed my loaded rig out of the "woods" to the highway. That was in Virginia and Southern Maryland at low altitude and with the stock mechanical fuel pump.
Things changed when I moved to Utah. The first time I hauled a heavy load at high altitude, fuel delivery became a vapor lock nightmare. Installing a Carter electric fuel pump under the bed just downstream of the dual tanks solved the fuel delivery problem and I've been hauling my boats - heaviest = 10,000 lbs boat and trailer - with no vapor locking or other fuel delivery problems since installing the electric fuel pump in 1986.
Though a 4.10 axle is ideal for towing, your 460 with your existing ratio should be OK. Diesels and the 460 do well towing with lower axle ratios.
Old Apr 28, 2005 | 10:12 AM
jimandmandy's Avatar
jimandmandy
Fuel delivery (vapor lock) is not the only problem. Lack of air density means that your power will drop about ten percent for each 3000 feet above sea level, so 200hp becomes 140hp at 9000ft, even with perfect jetting. The only compensating factor is the cooler air at altitude that slightly increases air density.
Taking off from Big Bear Lake, CA airport in a non-turbo Cessna in summer was a frightening example of this. Even with a manual mixture control and proper leaning, I thought I was going for a swim off the end of the runway.
Jim
Old May 2, 2005 | 09:34 AM
pops_91710's Avatar
pops_91710
Originally Posted by yz250roost
Hey guys,
Jeff
I towed for years with a E-350 with 3.55 axle ratio and a 4 barrel carb over the Sierra's, Rockies, and all points in-between there and Chino, California with no problems. It was jetted rich. Only time it would load up was above 8,000 feet on cold morning starts. Revving it blows it out.
Lower floats to run leaner?? Never heard that one before!
By the way, did you mean (F)-350 suspension or 3.50 gearing?
Remember, Tires sizes will change effective gear ratios. So if they are larger than factory, a 3.50 will not be a true 3.50 ratio. It will be less and less effective.
Jetting on the go is not a good or feasible idea. That stuff is for racers only.
Old May 2, 2005 | 11:44 AM
yz250roost's Avatar
yz250roost
Sorry, There was a confusion when I said 350 rear suspension I didn't mean 3.50 gear ratio, I meant that it's a 1 ton rear suspension. I have 4.10 in the diff.
-Jeff
Thanks for all the help. I've gotta get those 35" tires off the back though, I know that won't help at all.
Old May 2, 2005 | 12:26 PM
pops_91710's Avatar
pops_91710
4.10's will serve you extremely well.
Old May 20, 2005 | 12:45 AM
jimrat's Avatar
jimrat
Another trick for cold high altitude starts is to put a choths pin on the carb butterfly to keep it from closing all the way. reduces flooding and over rich starts.
Old May 20, 2005 | 06:52 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
The electric fuel pump will be the best thing that you can do it will stop any vapor locking. On my last carbed 460 I even removed the mechanical fuel pump and went electric only.
Denny
JNG6
Jul 8, 2014 10:52 PM
2006White60
May 4, 2014 11:35 PM
keyston44
2009 - 2014 F150
15
Mar 10, 2014 09:00 PM
dwilliamsceg
6.4L Power Stroke Diesel
19
Sep 22, 2010 08:29 AM
