Sponsored by: Real Truck
Door Chime Death
Old Jun 19, 2005 | 05:08 PM
  #31
south_paw's Avatar
south_paw
Just did it!! Another quiet 05. Thanks
Old Jun 20, 2005 | 03:47 AM
  #32
rhino_160's Avatar
rhino_160
anyone know which wire it is for the 1999 F-150 door chime thing??thanks in advance
Old Jun 20, 2005 | 05:08 AM
  #33
bterry's Avatar
bterry
South_paw, Did you cut or tape?
Rino_160, I'll bet the tape solution will work on your 150. I believe it uses the same lock cylinder as the superduties.
Old Jun 22, 2005 | 04:09 PM
  #34
gregmck's Avatar
gregmck
Originally Posted by bterry
This is the best way. I takes the same amount of time, and doesn't hack up the wiring. Besides it's VERY easy, and not permanent.
Here's some more details:
-Take the lock cylinder out by inserting key > turn to on > insert slim tool (I used my test probe) in the hole under the cylinder. Pull out the cylinder.
-Put electrical tape between the contacts on the "key in" switch. It's on the side, easily found by taking key in and out. You'll see the contacts.
-Push the lock cylinder back in.
Done.
Thanks for the great tip Autobahn F-250 Lariat.
Tried that this morning. Couldn't get the cyl out. What could I have done wrong. I thought I saw a little ball detent thing in one of the holes, turned on key, pushed up on ball with small screwdriver, key cyl would not come out. Now I see wires, were my eyes deceiving me w/ the "lock ball". I've turned the key every which way but loose and everything seems to work fine, I just can't get the cyl out.
Thanks.
Old Jun 22, 2005 | 05:06 PM
  #35
bterry's Avatar
bterry
gregmck, you shouldn't be seeing any wires. I'm confused about that statement, but you do not take any plastic covers off, if thats what you did. Any way, there are five holes holding the plasitic cover on that's located under the steering column. Poke around the only non-symetrical one. It's right under the ignition lock. With the key on, you should be able to pull the whole black thing straight out (the thing that the key goes into). I guess the trick is: key on, poke the correct hole, pull straight out. I'm not sure if it's a "lock ball" or not. If you still have trouble, I'll take a photo.
Old Jun 22, 2005 | 06:28 PM
  #36
gregmck's Avatar
gregmck
I owe ya a beer buddy! I tried again and there is no ball lock, I was just seeing things w/ my poor middle age eyes.
Yes there were wires visible. If you poke around there are some in the area, in my case they just happened to be in alignment with the access hole. I got the cylinder out, put on a small square of electrical tape and wow, no chimes.
Makes a good truck even better! When I'm messing around hooking up a trailer the ding ding ding just drove me nuts. Thanks again to all who contributed.
Old Jun 22, 2005 | 08:15 PM
  #37
rhino_160's Avatar
rhino_160
sorry guys but i am lost on this buzzer silencer trick with the tape..i have a 1999 F-150 sport and don't quite understand what to look for..thanks
Old Jun 25, 2005 | 06:47 PM
  #38
bterry's Avatar
bterry
Sweet! Just send it to my beerpal account.
Old Jun 25, 2005 | 06:53 PM
  #39
bterry's Avatar
bterry
Please re-read posts #27 and #35, and elaborate a little more as to what you don't understand. I'll try to help if I can.
Old Jun 26, 2005 | 07:35 PM
  #40
stbrem's Avatar
stbrem
Originally Posted by Moonblink
The wire on my '05 Superduty was black with pink stripe. I just pulled apart the grey connector, pulled out the middle strip between all the connectors and removed the whole pin which holds the black/pink wire into the harness. Make for easier re-install than splicing the wires back - just in case a future owner likes that noise.
Thanks.
I just did it this way today. Worked great, and easy to put back in the future because nothing is cut.
Stephen
Old Jul 17, 2005 | 02:58 PM
  #41
Gloveman's Avatar
Gloveman
I hope I did not screw something up, but here is what I did on my 06.
I removed the cylinder, on top of it was a contact plate, below the main conctact plate is a small contact actuated by an orange piece of plastic that moves when the key is moved.
I just popped off the upper contact. I saved it and it looks easy to put back in if you guys tell me I did something terrible. The truck started right up but I have not driven it yet.
Oh, The Chime is no more.
Old Aug 14, 2005 | 12:40 PM
  #42
rtoy's Avatar
rtoy
Another simple way is to remove the key assembly and just put a piece of tape over the contacts. works on mine for 1 year now.......F250 /05
Old Aug 14, 2005 | 01:50 PM
  #43
SuperBlue's Avatar
SuperBlue
That's great! I heard that if you were to remove the chiming buzzer you would mess up your computer.
Old Aug 14, 2005 | 03:36 PM
  #44
locash's Avatar
locash
I also disconnected mine on my 2002 F350.. I preferred the method of finding the plug and de-pinning the wire from the plug, then put a piece of shrink tube on the contact and cooked it. If I ever need to hook it back up, I remove the shrink tube, put the pin back into the plug, and all is good.. I'm glad I dont have to listen to that piece of junk anymore, as it would beep even if the key wasnt in the ignition, unless I jiggled the lock cylinder.. damn that thing..
Thanks again to whoever started this thread..
txtwang48
Jul 12, 2021 02:01 AM
sgrol
6.7L Power Stroke Diesel
May 12, 2014 02:40 PM
Adventure Rider
Sep 8, 2012 01:57 PM
truckalpers
1997 - 2003 F150
Nov 2, 2005 03:00 PM
drewg123
Sep 12, 2005 12:17 PM
