Inertia switch voltage
Old Apr 24, 2005 | 11:23 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I only have 7 volts to the inertia switch on my 2.9 88 BII. Should I have 12 volts? I have no fuel pressure and am trying to figure out the problem.
Old Apr 24, 2005 | 11:28 PM
Ford_Six's Avatar
Ford_Six
Check the fuel pump relay, the connector may be corroded. You are right, it should be 12v.
Old Apr 25, 2005 | 12:21 AM
97Centurion
Rub my Belly
Thanks! Where is the relay located? I just picked this thing up today and haven't had the chance to pick up any manuals for it yet.
Old May 9, 2005 | 12:23 AM
vaquero32's Avatar
vaquero32
i thought i had this same problem with my 99 F350 and i turned out to be incorrect. Checking it against another 350 at work showed that the pump does in fact only receive 7 volts with the key turned to on.
now using a scan tool to test the pump as the manual suggests got me 10.5 on both.
i replaced my fuel pump and problem was sovled.
Lascar
1983 - 2012 Ranger & B-Series
Aug 27, 2016 04:23 PM
efiles123
Dec 13, 2015 11:59 AM
jmoore1045
Electrical Systems/Wiring
Apr 20, 2015 02:38 PM
VannerDude
Feb 22, 2015 01:54 PM
Tex311
Apr 5, 2003 12:58 AM
