86 ranger fuel system
Old Apr 17, 2015 | 07:43 PM
jmoore1045's Avatar
jmoore1045
I am trouble shooting a no start issue on a 86 ranger 2.9l pickup. I have no power to the inertia switch and need to know how it is powered and from where. Would love a wiring diagram if possible.
I have battery power to both relays and koeo power also but the pumps do not run. If i put 12 volts to one side of the inertia switch the pumps do run.
Thank You
Old Apr 17, 2015 | 09:42 PM
Franklin2's Avatar
Franklin2
Here's a diagram.
Check the darkgreen/yellow wire leaving the relay.
Old Apr 18, 2015 | 10:07 AM
jmoore1045's Avatar
jmoore1045
thank you very much
Old Apr 19, 2015 | 08:29 PM
jmoore1045's Avatar
jmoore1045
still do not understabd where the power to the inertia switch comes from, does the ecm power the relay or is it powered from the fuel pump relay?
Where does the signal to energize the fues system com from?
Sorry for so many questions, but it has been many years since I worked on any fuel injected vehicles
Old Apr 20, 2015 | 02:38 PM
Franklin2's Avatar
Franklin2
Both.
Look at the relay in the diagram. The squiggly line is the coil of the relay. It receives power from the ecm relay all the time the ecm relay is closed. But even though it has power from the ecm relay, it still does not function. If you follow the circuit through the squiggly line, it goes to the engine ecm. This is the ground for the relay coil. When the ecm verfies the engine is turning(pulses from the dist) it goes ahead and grounds the lightblue/orange wire, which makes the coil in the relay energize.
When the coil energizes, this makes the circuit to the left in the little relay picture. This circuit is what actually sends power down to the inertia switch. It's fed from 30a fuse from the fuse box.
Bronco POPO
Bronco II
Mar 4, 2011 12:44 PM
sailorjohn
Electrical Systems/Wiring
Dec 31, 2008 07:50 AM
gman41364
1983 - 2012 Ranger & B-Series
Aug 8, 2007 11:46 AM
2wheeljohn
Nov 14, 2006 09:30 AM
pberish
Mar 14, 2005 07:57 PM
