No power to Ranger fuel pump
The fuse and relay have been tested. There actually is 5 volts at the fuel pump.
The truck was running OK when the clutch went out. It wouldn't start after the clutch was replaced. The inertia switch is OK. I don't know where to look now Any help will be appreciated.
Lascar
Lascar
Here is a link to many wiring diagrams that might help ,,Pawpaw sent this to me when I joined this site and it has been very useful Search Wiring Diagrams
Just took a quick look at the link that spooktn mentioned (thanks spooktn/Pawpaw) some Fords do & some dont use a fuel pump relay. This 98 does have a pump relay. It's number 5 under the hood in the power dist box.
Number 7 is the horn relay, if it's identical to number 5 swap them with each other and see if your fuel pump works.
I see the online diagrams dont agree with your owners manual??? Go figure.
Try removing the lid from the relay box & flip it over. If theres a diagram look at the pump relay & the horn relay & if they are identical swap them with each other & see what happens. If not the horn relay maybe the AC or wiper relay is identical. Just dont use the PCM power relay.
ptm
1983 - 2012 Ranger & B-Series
05-03-2013 09:17 AM
