Engine ran radically.will not start
Old Apr 18, 2005 | 10:35 AM
Jerry ranger9's Avatar
Jerry ranger9
Engine ran radically. 2.9 lit. ranger, fuel injected, 5 speed. What transpired, I had just driven for 20 minuets, on belt way to heat it up to temp, ran good no problems. Stooped to shop for 1 hour, when I started it up it started to knock hard and shake, oil pressure dropped, and the lifters rattled radically not just tapping. I drove it for ten miles on and off it would get better and worse but never returned to full power. Now it will not start, wants to fire up, one or two cylinders fire. I have disconnected the exhaust so it is not the cat, checked the wires acceptable resistance, added new plugs, plan to check the rest of the ignition system but could it be in the fuel distribution system, like maybe a clogged filter, injector problem or a leak, any ideas or experience? any help appreciated.
Old Apr 19, 2005 | 01:54 AM
Ford_Six's Avatar
Ford_Six
What did the old plugs look like? Also, what does the oil look like?
Old May 9, 2005 | 08:16 AM
Jerry ranger9
The plugs were Champion copper plus, two were reddish in color and others were normal, dark black. One had electrode erosion on a slant slopping down towards the electrode. The oil was dirty, nothing unusual, no water in it.
I changed the oil pump, and screen, while doing this I had no pressure on the fuel rail, at the pressure regulator. I want to check both fuel pumps, so I figured I would disconnect them some where to isolate the pumps and feed battery voltage to them, But I need some hose and clamps first. I also had problems with a fusible link, 20 g. the engine would cut out, and just puff, sort of, but it stopped, and I could not and still can't find any locally to replace. Know of a place on line that takes checks for parts?
Old May 9, 2005 | 02:49 PM
LxMan1's Avatar
LxMan1
Sounds like it may have jumped time.
You could temperarily put an inline fuse holder in place of the link and put a 20amp fuse in it.
third_edition
1947 and Older Ford Trucks
21
Jun 6, 2016 01:31 PM
Camjonik
2004 - 2008 F150
Aug 17, 2015 01:09 PM
joedirt9369
28
Jan 14, 2015 03:27 PM
rockher_man
Sep 16, 2010 06:10 AM
fuzz
Jun 29, 2004 01:03 AM
