Offroad & 4x4
Crossover steering question
Old Apr 22, 2005 | 10:36 PM
Momudder720's Avatar
Momudder720
Alright, I've got my heims for the knuckles, and I've got the tube and the tube adaptors to keep the front wheels aligned. How do I attach the drag link to the tie rod? I was thinkin of getting everything lined up, then welding two pieces of 3/16 plate to the tie rod, and putting a bolt thru it and the heim attached to the drag lonk, but that'd take away the ability to adjust the alignment. Suggestions? I was thinkin of making a sleeve that would 'float' on the tie rod between two stops, but I'm not sure that would work. Should I just run the drag link/heim over to the PS knuckle, and put the tie rod under the knuckle, as opposed to over the knuckle?
Old Apr 23, 2005 | 12:04 AM
ivanribic's Avatar
ivanribic
On those setups I think it's best to do the tie rod under the knuckle and the drag link over. You'll need a shim or bushing of some sort to lift the heim on the drag link just a little so it doesn't bind and seperate the joint. This is one of the reasons it's a better option to use a TRE on a drag link than a heim, but if the angle isn't too much you should be okay.
Old Apr 25, 2005 | 12:38 PM
Momudder720
There isn't too much of a stupid angle there, so I should be ok with just running a heim over to the knuckle and getting a little bit longer bolt. Just what I was looking for.
Old Apr 27, 2005 | 02:12 AM
lowcountry's Avatar
lowcountry
If you check out www.performanceunlimited.com they have a good steering setup and parts available to do your own.
bigcrunch
Mar 10, 2017 08:41 PM
Bossman7121
Apr 10, 2011 09:21 PM
scatgo
Offroad & 4x4
27
Mar 24, 2011 07:57 PM
quaallen
Offroad & 4x4
13
Feb 23, 2011 02:18 PM
rbhug
Dec 1, 2010 11:11 AM
