Offroad & 4x4
Heim Joints
Old Mar 20, 2011 | 04:27 PM
scatgo's Avatar
scatgo
Heim Joints
How would you use a heim joint on the front end of a truck? The tie rod ends have a tapered bolt that goes through the pitman arm, steering knuckles etc. etc. Would you drill out the taper for a bolt or do they have tapered bolts for use with heim joints? Links to web sites that sell good heim joints would be appreciated.
Old Mar 20, 2011 | 05:20 PM
ibleedblue1385's Avatar
ibleedblue1385
Just drill it out. Check out ballistic fabrication, they sell heims.
Old Mar 20, 2011 | 10:25 PM
scatgo's Avatar
scatgo
Thanks. I guess the next question would be what size bolt would you go with on a F 350 with a diesel engine. 1/2 inch 5/8? grade 8 maybe 10?
Old Mar 20, 2011 | 10:32 PM
captain p4's Avatar
captain p4
5/8 minimum, I'd drill it out to 3/4. A 5/8 bolt fits and will work without drilling it out on an 89 d60 I know for sure (the front of my Bronco), but while it works and isn't necessarily unsafe there is the tiniest amount of play. I'm going to drill mine out whenever I get around to it, already have the 3/4 heims, just haven't had a chance to do it. Also haven't been able to find a 3/4" bit at any of the local stores, but haven't looked too hard either.
Old Mar 20, 2011 | 10:42 PM
scatgo's Avatar
scatgo
And just how crazy should you go with the tubing 1/4 1/2 3/4 wall?
Old Mar 20, 2011 | 11:44 PM
captain p4's Avatar
captain p4
I can't remember the exact size of mine, but I believe it was 1.25 OD and small enough ID that it could be tapped for a 3/4 thread (3/4x3/4 heims, one LH and one RH thread, obviously). I think the specifics are in my D60 swap thread. Chromoly tubing too, if you go with DOM then something a little bigger with weld in bungs will work a little better strength wise.
Old Mar 21, 2011 | 03:28 PM
hav24wheel's Avatar
hav24wheel
Paul, use a "Uni-bit" it will drill the required 3/4 inch hole easily.
I wouldn't go any smaller than a 3/4 hem. Grade 8 bolts is where its at.
Old Mar 21, 2011 | 04:48 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
I have TREs on my crew but i used 1.5" OD 1/4" wall DOM. I really wouldny use heims on a truck with alot of street use.
Old Mar 21, 2011 | 06:19 PM
scatgo's Avatar
scatgo
TRE's ?????
Old Mar 21, 2011 | 06:49 PM
hav24wheel's Avatar
hav24wheel
Tie rod ends
Old Mar 21, 2011 | 07:36 PM
crazyredneckanyhow
Basic chevy tie rod ends. Im uploading some pics now of my steering setup i just got done with.
Old Mar 21, 2011 | 07:45 PM
crazyredneckanyhow
Old Mar 21, 2011 | 07:57 PM
kjett's Avatar
kjett
You didn't ask me, I've got one
Old Mar 21, 2011 | 10:07 PM
captain p4's Avatar
captain p4
Hook me up fatty
Old Mar 23, 2011 | 07:13 AM
alpha/omega's Avatar
alpha/omega
Ive got one too Paul but obviously you didnt ask me either. :flipoff:
Cheet-hoe, that DOM looks familiar.
Change the color on that diff cover...now.
