I got the cheapo duralast front drums from autozone and the holes for the lugs are to small to fir over the wider base of the stud should I just drill them
If these are front drums there made to be press fit to the studs like the oem ones.
You'll need to press out the studs put the drum on the hub line up the stud holes and pres one stud in at a time with a tube on the other side to hold the drum from bowing out.
It shouldn't cost more then $10 at a machine shop.
Yes you can drill then but be aware you might have a pulse in the pedal. the drums are stud centric not hub centric. This is why when machine the drums you use the hub.
