power brakes with drums
Originally Posted by 51fordrodder
Ok I orderd a power brake unit for my 51 f1 its got a disc/drum master cylinder
is there any way i could use that master cylinder on a drum/drum set up?
The only reason a disc/drum MC would NOT work for drum/drum is if it has built in proportioning valve and or residual pressure valve, many do not but use a separate valve. all you would need is the correct proportioning valve or an adjustable one. The biggest difference between a disc/drum and a drum/drum is the former has a larger chamber for the disc brakes as they require more volume. Check with your manufacturer tho for the definite answer.
lefty rodan
01-15-2010 08:18 PM
joditruck
08-13-2007 06:39 AM
farmtwuck
36
10-09-2005 08:34 AM
snipa
10-17-2004 03:12 PM
mwc4275
08-18-2002 10:17 PM
