Do It Yourself Oil Change
Old Apr 19, 2005 | 10:29 PM
  #31
Mud Doc's Avatar
Mud Doc
take em
oil filter is 36mm and it fits the HFCM fuel filter also; top gas filter is smaller hex, not sure of size, but a 1/2" drive rachet will fit it also.
Old Apr 20, 2005 | 07:37 AM
  #32
pdbd's Avatar
pdbd
Dump 3 gallons in then 1/2 a quart at a time until the dip stick shows 1/2 into the hash marks DO NOT overfill. It should be around 13.5 to 14.5 quarts (can't remember)
Old Apr 20, 2005 | 10:48 AM
  #33
sweet03cobra's Avatar
sweet03cobra
sounds good, thanks for all your help.
Old Apr 23, 2005 | 07:17 PM
  #34
nhebert's Avatar
nhebert
Originally Posted by take em
I'm getting ready to change oil. Ordered and received 6 filters from oil guard and my fumotovalve. I remember someone having a post as to a socket that fits both the oil filter cap and the fuel filters. I have done a search and read back through 13 pages of threads to find where it was. Can someone direct me to the website that carried the special tool or the post it was located at. Does Motorhaven carry it? Maybe list it on the tech site for tools used to help with oil/fuel filter change.
Oil Filter cap nut is 36 MM , get a 36mm 1/2 drive socket<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Apr 23, 2005 | 07:44 PM
  #35
utahtom's Avatar
utahtom
(6.0 Diesel) Broadcast Message 1512 & 1574: Do not add oil if the level is above the "Min" line on the dipstick.
Great advice direct from Ford Motor Co & brought to you by your friends at FTE
Old Apr 24, 2005 | 11:01 PM
  #36
Michael013's Avatar
Michael013
I just did my first oil change at Jiffy Lube and have an updated price. They were tacking a $40 surcharge for the filter, NO MORE. My total for a Rotella oil change with sales tax was $51.48 and after a 10% discount, which almost everyone can get. Plus they check everthing else and the old oil goes back to the right place (hopefully)
But if you like changing your own oil and disposing of it.........Have Fun
Old Apr 25, 2005 | 06:53 AM
  #37
pdbd's Avatar
pdbd
Walmart and Advanced auto take used oil for free.
Old Apr 26, 2005 | 03:53 PM
  #38
SDCREW4D's Avatar
SDCREW4D
The socket is made by Lisle the part # is 14500. They can be order at Pep-boys,Carquest and O'reillys. I got mine at O'reillys for $8.95.
Old Apr 26, 2005 | 05:48 PM
  #39
Skweeker's Avatar
Skweeker
You are looking for a 36mm socket to be used for both the engine oil filter cap and the large fuel filter cap located on the frame rail. I do not remember the size for the engine fuel filter cap unfortunately.
Old Apr 27, 2005 | 09:13 AM
  #40
take em's Avatar
take em
Thanks all for the info on the use of a 36mm size. I was looking for a 36mm socket that is only 1/2 to 3/4 inch high it is made by a speciality tool company for the ford filters. I had read about someone using one and they had a web site that showed the tool. Thinking back... it might have been on one of those other diesel sites. Thanks again.
Old Apr 27, 2005 | 04:12 PM
  #41
take em's Avatar
take em
Found what I was looking for. Lislecorp carries a 36mm socket made especially for the oil/fuel filters on the PSD 6.0. etoolcart.com also carries it, but I ordered mine from my local auto parts store. Cost was $8.99.
Old Apr 27, 2005 | 06:07 PM
  #42
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Great price for that, would have bet money it would be a 20/25.00 hit
Old Apr 28, 2005 | 10:00 PM
  #43
3/4ER's Avatar
3/4ER
Just got back from WalMart, good news, Fram filter replaces MotorCraft at a lower cost ($15.27).
Finally Mobil 1 Truck & SUV is available in 5qt jug for $19.97.
Last, but not least, Rotella T 5W40 Syn CI-4 rated is $13.48 for gal jug.
Fram#9549 is the same original equipment filter as the Motorcraft, just repackaged.
Old Apr 29, 2005 | 11:53 PM
  #44
Caballinsprings's Avatar
Caballinsprings
Mobby,
you have the 6.0 PSD ? and you are changing oil every 10,000 miles?
Originally Posted by MobeyDick
K&N Filter at Discount Auto Parts $14.98
Mobil 1 at Wally World 3 5Qt Jugs $60.00
Do that every 10,000 miles!!
Grinder Man
Oct 10, 2014 09:35 AM
jetact
Sep 14, 2010 09:30 PM
Technocrsr
Feb 17, 2007 09:13 AM
92Bronco-SA-TX
48
Aug 9, 2005 02:55 PM
1bgredtk
Nov 9, 2004 10:26 PM
