86 e150 scanner code
Old Oct 28, 2000 | 10:10 AM
wastelands's Avatar
wastelands
I hooked up a scanner to my 86 e150 van because I was having trouble with my fuel pump not coming on.
It gave me a code detecting problems with the edis (electronic distributorless ignition system). I don't know what this is or what to do next. Thanx for any help.
Jeff
Old Oct 28, 2000 | 11:45 AM
PAUL_2's Avatar
PAUL_2
An 86 E150 did not have Edis . If the fuel pump isnt running a code scanner will be of little help to you . First check the fuse , relay , wiring to & from the pump . Also check to see if the Inertia Switch has been tripped .
Old Oct 29, 2000 | 10:07 PM
hecticgb's Avatar
hecticgb
Check all of your wiring also. Just a few months ago i had a problem with a wire that just got corroded and the pump wouldnt turn on. I believe the new harness for it was like $19.
Troy
Old Oct 29, 2000 | 11:30 PM
PAUL_2's Avatar
PAUL_2
kjjr20
Jan 31, 2014 09:13 PM
Me86
2004 - 2008 F150
Sep 11, 2009 02:24 AM
quisp-n-quake
Jan 21, 2006 06:03 PM
18inchapes
Aug 3, 2005 02:48 PM
