Help!!!!
Old Sep 9, 2009 | 12:15 PM
Me86's Avatar
Me86
Help!!!!
Hi I have a 2007 Ford F-150 that it is rough at idle and when I put the scanner three codes appeared which are P0316, P0748, P0962. Does anybody know what to do?
Old Sep 10, 2009 | 04:40 PM
Oldguy4's Avatar
Oldguy4
Google "ford diagnostic codes". Better yet, It should still be under factory warrranty, take it in and have them tell you what's wrong.
Old Sep 11, 2009 | 02:24 AM
FTE Trigger's Avatar
FTE Trigger
FTE also has a partial OBDII code listing here... https://www.ford-trucks.com/article/idx/7/0/
P0316.....Crankshaft Position System Variation Not Learned
P0748 ......Pressure Control Solenoid Electrical
P0962....Pressure Control Solenoid "A" Control Circuit Low
On Edit:
Could you double check the xx316 and the xx962? A few of the lists I have does not have the 962 listed as a "local" Ford code, and the 316 was skipped on a few of the lists. It jumped from 315 to 320 on some lists...fyi.
ItsMREMT
Nov 8, 2024 09:34 PM
Tile man
2004 - 2008 F150
Apr 18, 2017 08:51 PM
Stevenmed
2004 - 2008 F150
Mar 11, 2016 10:28 AM
advan550
Jun 14, 2014 05:18 PM
