Governor Removal?
Old Apr 13, 2005 | 01:41 AM
beefcake712's Avatar
beefcake712
Governor Removal?
I have a 2005 F-350, CC Lariat with a 6-speed manual. I installed the Edge Juice w/ Attitude controller and the DPS 2-stage Water/Meth injection system . The problem I ran into is that I still have a speed limit of around 99MPH .
Is there a way to change this with the Edge? Is there a way to adjust the governor without a tuner? If some one could help me with this I would appreciate it greatly. I love the edge , but want to get rid of the speed limit.
Old Apr 13, 2005 | 06:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
beefcake712 be sure to read the welcome...click below to find it
https://www.ford-trucks.com/forums/s...d.php?t=325000
Old Apr 14, 2005 | 02:27 PM
tiredlr's Avatar
tiredlr
Governor Removal
Beefcake
U Might Want To Consider Getting A Sct Xcalibrator With A Custom Tune To Stack With Your Edge Fueling Box, I'm Currently Unaware Of Any Add On Device To Remove The Top Speed Limiter. The Sct Will Also Tune Your Shifting, A Good Idea When Your Running The Edge Juice, As It Does Nothing For The Tranny. ...mark
Old Apr 14, 2005 | 02:48 PM
Daryl Hunter's Avatar
Daryl Hunter
In this case neither would the SCT as he has a 6-speed manual transmission
Old Apr 14, 2005 | 03:00 PM
beefcake712
Yeah, I was looking at the SCT. I saw it was capable of holding 3 programs and could be customized. What would be the posibilities of stacking it with the edge using a mild program on the SCT also for more power? I do have open exhaust and the DPS 2-stage water injection system to lower EGT's. I am mostly worried about the extreame timeing advancement this would cause and the clutch's ability to grab.
Old Apr 14, 2005 | 07:58 PM
tiredlr's Avatar
tiredlr
I Stand Corrected On The Shifting Daryl, Maybe I Should Slow Down A Bit When Reading A Post
Old Apr 14, 2005 | 11:01 PM
Fastest1's Avatar
Fastest1
Actually BD Power makes a box that will eliminate just the limiter, 200 bucks, I think.
Old Apr 15, 2005 | 06:56 PM
569104's Avatar
569104
Check with the CA voters, they were successful in removing the Governor.... ....I couldn't resist.
dougx
Large Truck
May 9, 2020 09:53 PM
wcasey
Nov 4, 2016 07:48 PM
Lance1379
2009 - 2014 F150
52
Aug 8, 2016 06:44 AM
79-ford-f150
2015 - 2020 F150
24
Mar 3, 2016 07:54 AM
Macrobb
13
Jun 21, 2014 01:06 AM
