NewB here with problem
Old Apr 12, 2005 | 08:27 PM
HawaiianPSD's Avatar
HawaiianPSD
I have a bone stock 01 F-250 PSD CC with 55K miles. Only aftermarket change is tires. My problem is my truck stalls out. I can be driving and it will either stall for a split second and run again (because it's in gear I figure it jumps itself) or just plain quits. If it quits, it sometimes takes a little cranking to get her started again or it can fire right up. Usually it just looses all power for a split second and will be fine for the rest of the drive. For some reason it just happens under acceleration or under load as when I drive home from work it's all down hill for 35 or so miles and it runs just fine. Anybody have this problem before or know what it might be? Thanks for any help!!!
Old Apr 12, 2005 | 08:35 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 12, 2005 | 09:03 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Most likely it's a CPS sensor, located to the side of the flywheel, about $120 from an International dealer or around $200+ from a Ford dealer. Seems to cure just about any stalling problem. If you do a search on this site for stallling you will have plenty to read for awhile. More will chime in, just wait! Welcome to FTE
Old Apr 12, 2005 | 10:02 PM
touchofgrey's Avatar
touchofgrey
Yep, sounds like the ol CPS problem.....one of the few you will ever encounter. The 7.3 is pretty reliable overall. I have seen them for around $40 .
Old Apr 12, 2005 | 10:13 PM
HawaiianPSD
Thanks guyz!!! I'll take a look at the CPS.
Old Apr 13, 2005 | 08:56 AM
CHRISTIANMAN316's Avatar
CHRISTIANMAN316
Have you changed your fuel filter recently, I have also noticed the same types of problems with a clogged fuel filter, might try that first!
Old Apr 13, 2005 | 09:03 AM
HawaiianPSD
In fact I just changed it about 2 weeks ago with no difference. Thanks for the suggestion though!
Old Apr 13, 2005 | 10:54 AM
Max1775's Avatar
Max1775
Where'd you find em that cheap? The best I've found is $70+ on ebay. I'd sure like to pick up a couple extras for that price.
Max
Old Apr 13, 2005 | 11:06 AM
tjbeggs's Avatar
tjbeggs
napa now carries cam sensors for the psd's not sure of the price though i get my parts at cost but they are cheaper and IH or ford and easier to get.
Old Apr 13, 2005 | 03:19 PM
vancouverpower's Avatar
vancouverpower
BTW it's located above the crank pulley, not the flywheel.
Old Apr 13, 2005 | 06:35 PM
HawaiianPSD
Replaced the CPS yesterday and it cured the problem. Thanks alot guyz, really appreciate it!!! Aloha!!!
Old Apr 13, 2005 | 06:42 PM
Robbgt's Avatar
Robbgt
Awsome!! good to hear.... these guys are good... how much did the CPS run you?
-Robb
Old Apr 13, 2005 | 11:06 PM
HawaiianPSD
Costed me nuthin'. It was covered under my warranty.
Old Apr 13, 2005 | 11:46 PM
Powerstrokedlariat
Thanks, the really bad thing is I replaced mine a few weeks ago, you would think I would remember where it was at!! Brain was working, typing fingers were not-
PiP.Squeak
29
Apr 4, 2015 11:08 AM
kawkx500
Oct 15, 2012 09:18 AM
HawaiianPSD
27
Oct 2, 2012 06:01 PM
jorda23
Oct 3, 2006 09:00 AM
obars
Aerostar
Jul 8, 2005 05:52 PM
