Can't narrow down problem
Old Apr 7, 2005 | 01:10 PM
dijitolboy's Avatar
dijitolboy
Thanks to anyone who helps me out with this.
I have an 86 F250. It has acceleration problems (to put it mildly). If i try to push the gas AT ALL, the engine bogs down and acts as if it is getting none. In neutral, i can rev it up pretty high, but in gear it does the above. Here are some things that I can't decide could be the problem:
-battery terminals are pretty shot, but connected. I would bet they don't
allow full current, though.
-distributor cap was pretty nasty inside; i cleaned it and smoothed the
pins
-as far as i can tell, it has NO FUEL FILTER (truck had a questionable past)
the fuel line goes directly from the tank to the pump to the engine.
It has these symptoms on and off. At one point, it drove completely fine and i could bury the spedometer. then, it was having a slight problem and could only be accelerated slowly (by not pushing the gas more than an inch or so) with a top speed of about fifty...any higher and it would start buckin' like crazy. Now, i can't go more than 10 miles per hour or it freaks out.
WHAT IS THE PROBLEM??????
Old Apr 7, 2005 | 01:47 PM
yozsi's Avatar
yozsi
what type of engine and is it fi or carburated?
Old Apr 7, 2005 | 02:04 PM
Chugalug's Avatar
Chugalug
Try a new dissy cap and rotery button.
Old Apr 7, 2005 | 03:49 PM
Steve's Beast's Avatar
Steve's Beast
If your sure there is no fuel filter. chances are your carb is plugged! Look again it might be the type that screws on to the carb.
-If there was no fuel filter than you need to clean/rebuild the carb.
-If there was a fuel filter, just try replacing it and hope for the best!
Good luck!
P.S. Let us know if you solve the problem.
Steve
Old Apr 14, 2005 | 10:52 PM
fordtruckman23's Avatar
fordtruckman23
If none of the other troubleshooting works, check and make sure the exhaust system is flowing properly. Not plugged or maybe crushed pipe. I've done a little offroad damage to my pipes and lost power. Just something to think about. Hope it helps.
Old Apr 15, 2005 | 06:37 AM
bremen242's Avatar
bremen242
if it is a 4bbl holley, it could be it has a blown power valve.
Old Apr 22, 2005 | 09:26 PM
Chiefrider007's Avatar
Chiefrider007
I would think about all the wires, plugs, distributor cap and so forth and if they fail to solve your problem I would also change/check the control module. It controls spark and timing and could cause your problem as well.
Old Apr 22, 2005 | 09:41 PM
mustange70's Avatar
mustange70
This is a fuel realted problem more than likely, so first pull the fuel line off the bard, have a little gallon pail handy, and have someone turn the motor over so you can see it there's a nice steady flow, if not its either the fuel pump, plugged line or the tank, work your way back starting at the fuel pump (i'm assuming carb), oh there should be a little metal in line filter thingy if its a 2barrel motor right where the metal fuel line goes into the carb, very easy to clog this little filter up, then like i said wrok your way back all the way to the tank.
If this isn't the problem then its probably the carb, but that has been covered.
Old Apr 22, 2005 | 10:40 PM
travisd's Avatar
travisd
I think mustange70 is right on, I had the same thing happen and it was the fuel pump.
jNewill
1983 - 2012 Ranger & B-Series
Feb 23, 2015 02:58 AM
twise
Aug 20, 2014 06:02 PM
Shadow351
3.8 & 4.2L V6
Sep 2, 2011 11:22 PM
dcdave
Nov 30, 2007 01:15 PM
rompin78
May 21, 2005 09:25 PM
