Offroad & 4x4
tire pressure
Old Apr 5, 2005 | 07:32 PM
jimbob21rc's Avatar
jimbob21rc
Question tire pressure
i have got a set of 31x10.50x15 all-terrains and i was wondering what should my tire pressure be for mud and what should it be for rock?
Old Apr 6, 2005 | 12:40 PM
fishmanndotcom's Avatar
fishmanndotcom
ou will have to determine that.... there is no way any of us could easily guess b/c we don't know your rig, what kind of rocks, what kind of mud, the weight you are hauling, etc etc. just get off your butt and away from the puter and experiment some. i wouldn't go any lower than about 12-14psi with 15" rims and no less than 15psi with anything else. really whatever psi you use in the rocks should help just as much in the mud.
-cutts-
Old Apr 6, 2005 | 12:46 PM
redneckbrat's Avatar
redneckbrat
What he said.
I played in the snow a while back, went down to 15, worked great.
Old Apr 7, 2005 | 10:29 PM
peppy's Avatar
peppy
I've dropped as low as 20 out in the sand.....
Correct me if I'm wrong.....but I believe the greater the load range of your tire, the less you can drop the pressure. The stiffer side walls dont flex as much as lighter load tires. Therefore the high load range tires might loose the bead without enough pressure.
john fin
Jun 24, 2009 02:27 PM
Peter Nikols
1997 - 2003 F150
May 21, 2004 02:05 PM
SPELLY F150
1997 - 2003 F150
May 17, 2004 02:20 AM
SAR Ranger
Jun 3, 2003 11:00 AM
XXXcursion
Feb 11, 2003 04:15 PM
