Sponsored by: Auxito
Tire Pressure
Old May 20, 2004 | 06:11 PM
Peter Nikols's Avatar
Peter Nikols
Tire Pressure
Hello,
I have a set of Goodyear tires, and they may max pressure is 65 ft/lbs of pressure. I am not sure what Ford suggests for tire pressure, so I tried 50 ft/lbs. It is really bouncy. Should I try the max pressure.
Are there any temperatures I should be cautious of?
Thanks.
Old May 20, 2004 | 07:33 PM
triton_2002's Avatar
triton_2002
The max pressure is just that, the max. It is not the recommended pressure for routine driving. If you have it at 50 psi now and its bouncy, more psi will make it worse. I don't remember the exact psi right now but I believe its around 35 psi (this is all asumming you have stock size tires and rims) My truck has the recomended tire size/psi on the inside of the gas door, its also in the owners manual and I think its on the info tag on the door. Take care of this issue or you could have an blow out or at the very least your tires will not wear properly. Good luck.
Old May 21, 2004 | 10:00 AM
Peter Nikols
Blow out by over inlating. Right?
Old May 21, 2004 | 11:26 AM
karenj's Avatar
karenj
The max psi on the tire is for safety. Tires will increase in preasure due to expansion of the air when the tire gets hot, it's usually about 3-5 psi.I don't run my tires at max even when I tow, but I do increase the tire when I tow. If you increase your psi above comfort ride, but not max, it will help on gas milage, due to less drag.Like triton said if there not stock tires, go by what's on the tire.Example my tires max out at 65psi, but I run them at 46psi. Keep in mind if the tire is under inflated, it will wear on the outside of the tire and heat up more and yes possible blow-out, over inflated will wear the middle of tire. Hope this helps. Rich
Old May 21, 2004 | 11:35 AM
Peter Nikols
Thanks guys..
Old May 21, 2004 | 11:48 AM
Peter Nikols
Karen,
Do you also get that bouncy ride I'm talking about. 46 lbs is lower than what I put
and frankly I find it a bit too bouncy.
I was seriously looking at installing 33 in tires and I changed my mind because I was told it would be even worse. I was told to go with low profile tires on big rims to solve this.
Thanks.
Peter
Old May 21, 2004 | 12:09 PM
karenj's Avatar
karenj
I take it you have a 4x4 according to your sig. I would'nt go to low profile on a 4x4. What is yor size of tire? I have 33" tires and I have no problem of bouncing, just if I inflate to 50psi cold it rides hard. The bigger the tire the bouncier it will be, like a balloon.
Old May 21, 2004 | 12:33 PM
Peter Nikols
They are the stock Goodyear tires on 16 in. rims. About 31 in high.
Sometimes it feels like a balloon.
Peter...
Old May 21, 2004 | 12:45 PM
karenj's Avatar
karenj
Maybe it's not your tires, maybe shocks. Upgrade your shocks to an off road shock, Rancho makes good ones. Do you have the stock shocks? I changed mine cause they were to spongy.
Old May 21, 2004 | 12:53 PM
Peter Nikols
That might work. Which ones did you buy?
Old May 21, 2004 | 02:01 PM
karenj's Avatar
karenj
Rancho 5000 I have, which are self adjusting and Rancho 9000 are adjustable.
Old May 21, 2004 | 02:05 PM
Peter Nikols
Great.
Thanks a bunch.
RacinNdrummin
52
Dec 9, 2016 11:24 AM
vectrex
Jun 14, 2013 02:13 AM
Huntersbo
Aug 3, 2012 07:31 PM
Great Danes
6.7L Power Stroke Diesel
Nov 29, 2010 08:58 AM
RCrawler
Feb 20, 2009 09:57 PM
