Bronco II Ford Bronco II
Removing Pitman arm...
Old Apr 5, 2005 | 12:13 AM
RomerB2's Avatar
RomerB2
I need to remove my pitman arm to put a drop pitman on there.. anybody have any ideas to help me get it off? I've tried using a fork prybar and all sorts of stuff, and it feels like it's going to break the steering box and I really really don't want that. Any ideas?
Old Apr 5, 2005 | 04:24 AM
mjb1962's Avatar
mjb1962
You need a pitman arm puller. Use a good one as the cheap ones will break.
Mark
Old Apr 5, 2005 | 05:18 AM
RomerB2's Avatar
RomerB2
And where do I get this little tool? You think Autozone rents them out?
Old Apr 5, 2005 | 05:50 AM
MasterColt's Avatar
MasterColt
Yes you can rent them at autozone or buy 1
Old Apr 5, 2005 | 04:33 PM
RomerB2's Avatar
RomerB2
I looked online just wondering the price of one, and they're wanting like $80 for them! I think I'll rent one.
Old Apr 5, 2005 | 06:15 PM
mjb1962's Avatar
mjb1962
Just a word of caution. I bought one from AutoZone and it broke when I attempted to remove mine. I then went and bought one at a tool store that was made in the U.S. and it worked. More expensive but worth it.
Pitman arms can be difficult to remove, I tightend up on the tool a little at a time while tapping the arm with a hammer and it finally broke free. Go easy with the hammer as you may damage the box. You could try heating the arm while tightening the tool but I wouldn't as the metal could be weakened or the box seals damaged by too much heat.
Mark
Old Apr 5, 2005 | 06:36 PM
mjb1962's Avatar
mjb1962
I just re-read your thread and noticed your installing a dropped pitman arm. Make sure when your done that it is tight on the tapered shaft as I have seen arms that require additional washers to tighten properly. This is due to the arm being thinner than the stock one. The nut reaches it's torque setting before the arm slides far enough up the tapered pitman shaft and you end up with play in the steering.
Mark
Old Apr 5, 2005 | 10:18 PM
RomerB2's Avatar
RomerB2
Well I deffinately don't want play in my steering.. it's already going to the left a little.
Old Jul 2, 2005 | 01:03 PM
884x4broncoII's Avatar
884x4broncoII
have you tryed the BFH apporch?lol just kidding, works great on balljoints though, i dont know id try it on a stearing box
2001SuperDuty
Jan 31, 2019 01:12 AM
Pappys53
15
Nov 27, 2010 11:48 AM
bmacky14
Jun 22, 2009 08:41 AM
mrdavidkendall
Dec 29, 2004 05:46 PM
Carlene
Aug 2, 2002 02:11 AM
