Steering box "Rag" joint
Old Apr 4, 2005 | 11:06 AM
Triumph's Avatar
Triumph
Hey guys,
I have the standard steering box on my 66 F250, and I am wondering where to get the "Rag" joint (Part numbe, Description,etc.) from.
My is a little loose so I should probably replace it.
Another question along the same line: Is this joint also attached when I convert to power steering ?(which I will do eventually?
Thanks in advance,Thom
Old Apr 4, 2005 | 12:09 PM
RaleighDad66's Avatar
RaleighDad66
I have seen these in the "help" product line at parts stores like pepboys.
Old Apr 4, 2005 | 12:27 PM
Triumph's Avatar
Triumph
A better question would be....
1. Should I replace the entire steering coupling?
OR....2. Remove the coupling & replace the "Rag Joint".
What do you guys think is the best plan of attack?
Old Apr 4, 2005 | 04:22 PM
ZombieSlayer's Avatar
ZombieSlayer
I would replace just the rag joint if the coupling doesn't look bad (gouged).
Old Apr 5, 2005 | 07:14 AM
William's Avatar
William
Your local Ford dealer has a new plastic rag joint. Not cheap! But it will last for years and you can use it with your power steering setup when you are ready to install that.
Old Apr 5, 2005 | 08:06 AM
fast frank 66's Avatar
fast frank 66
i have bought them from the help product line also. i was going through about 1 a month until my steering box went. after i replaced the steering box, i haven't had a problem with them at all
Old Apr 5, 2005 | 09:24 AM
Triumph's Avatar
Triumph
Thumbs up
Thanks guys, I purchased the complete replacement through NPD. I didnt know about the plastic one though, (that sounds like a great replacement.)
The joint that was in there was the original so it was a little tore up. Should get to it in the next few days so I can get to work buttoning this this up for the summer trips.
badasssapper67
Feb 21, 2017 09:44 PM
vidaliaman
May 13, 2016 11:43 AM
soco
Aug 12, 2008 09:08 PM
Enzo500
May 9, 2006 08:53 AM
eduardo
1978 - 1996 Big Bronco
Oct 11, 2005 12:05 AM
