Simple problem... I think
Old Mar 31, 2005 | 10:19 PM
hdgjr's Avatar
hdgjr
I just noticed my battery light coming on at idle. The amp meter shows normal charge. What does this mean? My batteries have 120k on them. Everything else seems to be perfect. Could the batteries be going bad?
Any help and experiences appreciated.
Thanks,
Folks
Old Mar 31, 2005 | 10:20 PM
StraightlineInc's Avatar
StraightlineInc
Are they stock or have they ever been replaced? Most likely if they are original they are going.
Old Mar 31, 2005 | 10:26 PM
farmb0y's Avatar
farmb0y
Are you talking the idiot gauge on the dash? If so, that can only be trusted to a point. Get an multi-tester and put it on the batteries, I'll bet they are starting to get weak, but enough to make it look like that are charging fine.
Old Mar 31, 2005 | 10:29 PM
Bluesbandit's Avatar
Bluesbandit
Simple answer is "yes". The more complex answer is all of the above. The dash Amp meter reads amperage, not voltage, so it's doesn't tell you much about your batteries, but what your alternator is putting out. I'd go to a parts store and have it checked out pronto. Most part stores will test them for free (they want to sell you something...go figure), but you might have to tell them which battery to test, and interpet their results on your own. I would mostly likely guess you have a batt going bad, but figure it out soon as a bad batt and can take out an alternator and vice vercsa. It can be a vicious circle and get expensive.
Old Mar 31, 2005 | 10:49 PM
superrangerman2002's Avatar
superrangerman2002
Most of the time the light on the dash idicates that the Alternator is going bad and not the batterys.
Poor batteries will often take out a alternator as they force the altenator to work even harder to keep them charged up.
Puting a Voltage tester on a battery really doesn't tell you jack...you can have a battery that reads 12V but only has 30A in it. A load tester is the only sure way to test batteries.
Measuring voltage with the motor running can give you some hints on if they are charging, voltage should be in the 13-14V range.
My money says you will have to get a new alternator, and if you are getting a new altenator, new batteries are also in order.
Old Mar 31, 2005 | 11:13 PM
Kwikkordead's Avatar
Kwikkordead
Superrangerman is right: Battery light means the alternator is not charging. Most likely the brushes are worn out and barely making contact with the armature. If your batteries are truly that old replace them at the same time. BTW mileage means nothing to batteries, time only is the factor, IMO.
Old Mar 31, 2005 | 11:59 PM
hdgjr's Avatar
hdgjr
Thanks everyone, for your input. Kwikkordead- if the brushes are worn out is it simple enough to simply replace the brushes or do i need to get another alt.? do i need to remove the old one to get it tested?
I assume it would be wise to replace the batteries. What is the best & ecomonical way to replace them?
Old Apr 1, 2005 | 07:35 AM
superrangerman2002
IMO, you'd be much better just getting a new one, rather than trying to fiddle with the old one.
I've seen the testing done both ways....I'd just dial up your local parts house and just ask them which way they prefer.
And yes you should replace the batteries as per my last post. If you have a Sam's membership, they can often save you some money on some really good Nascar selects (a grp 65 batt ran me $56 a battery), and they can also test your alternator with out removing it from the motor.
Old Apr 1, 2005 | 08:25 AM
Kwikkordead
Again, what Superrangerman said.
Old Apr 1, 2005 | 10:01 PM
hdgjr's Avatar
hdgjr
Well it turns out the batteries were bad. Had the alternater and batteries checked and the batteries were very weak. Once replaced everything seemed to work properly.
Thanks for all the information.
Harry Griffin
CASTMASTER
Mar 13, 2013 08:28 PM
imlowr2
1997 - 2003 F150
Oct 17, 2010 05:12 PM
MOOOOOPS
Aug 29, 2009 04:54 PM
bigtexan99
Jan 11, 2009 11:36 PM
Hellrazor1
Jan 22, 2007 11:46 AM
