can i charge 1 battery while connected?
Old Jan 10, 2009 | 10:22 AM
bigtexan99's Avatar
bigtexan99
When charging a battery in my truck with a battery charger/tender, do i need to disconnect it from the truck? Or can I just put the charger on 1 battery, and it will charge both of them?
Someone told me to unhook the battery while charging, or it would destroy the other battery. My thought it the charge would just flow to both batteries.
Thanks
Old Jan 10, 2009 | 10:33 AM
totin_tools's Avatar
totin_tools
I would think that both batteries would charge. It might put to much load on the charger though. It isnt that hard to disconnect one of them and charge it. But if you have one battery that is going bad then you might want to have them both checked and see if they are bad. If one of the batteries is bad then you would need to replace both at the same time.
Old Jan 10, 2009 | 12:34 PM
triskit16's Avatar
triskit16
I always disconnect my batteries. I destroyed something on my boat one time doing this. Just dont want to take any chance on my truck!
Old Jan 10, 2009 | 10:31 PM
Steve_250's Avatar
Steve_250
I would disconnect, too easy to do it.
How old are the batteries?
If you are having problems with one of them replace both unless they are pretty new.
If you replace one or two, keep it or them for testing 12v stuff in the shop/garage.
Or, you could hook up 12v LEDs in the shop with a 5w solar trickle charge! LOL!
Lots of uses for batts that hold a charge when NOT cranking an engine.
Old Jan 10, 2009 | 10:48 PM
Izzy351's Avatar
Izzy351
I've never disconnected batteries to charge them. As long as you have a GOOD charger, it should be fine. I hate disconnecting my batts -- drives me crazy when the trip odometer loses its mind..... And I think you lose your KAM when you disconnect them long enough.
Old Jan 11, 2009 | 09:28 AM
mueckster's Avatar
mueckster
I just remove the ground cable, from one battery, to test and charge the batteries individually.
Old Jan 11, 2009 | 07:51 PM
Steve_250's Avatar
Steve_250
Noooo, Joe!!
Don't disconnect both at the same time!
One batt will hold everything up, just (probably) won't start.
Old Jan 11, 2009 | 08:06 PM
whjco's Avatar
whjco
I've never disconnected the batteries to charge them and have never had any problems. The batteries are wired in parallel so hooking your charger to one will charge both. It won't overload the charger doing this, it will just take a longer amount of time to fully charge the batteries.
Old Jan 11, 2009 | 11:36 PM
novice psd's Avatar
novice psd
+1 I totally agree, but to test you need to test them separately.
KDAVID1
Mar 13, 2015 03:00 AM
omni
Electrical Systems/Wiring
Nov 18, 2014 05:28 PM
berick
Feb 15, 2014 06:28 PM
fordtruckrodder
May 24, 2013 06:30 PM
fred_79f250
General Automotive Discussion
Jul 16, 2008 09:34 AM
