Bull/Push Bar install
Old Mar 31, 2005 | 01:12 PM
czcwest's Avatar
czcwest
Just curious how hard it is to remove the front bumber of 04 f-150 scab to remove the tow hooks and install a push bar? Any concerns about the air bag? Should I remove the fuse for them? Thanks in advance.
Old Mar 31, 2005 | 02:22 PM
kingfish51's Avatar
kingfish51
Why would you remove the bumper. Every push bar, grille guard, or bull bar I have seen only takes the removal, temp or permanent, of the tow hooks.
All it takes to remove a tow hooks is remove 1 bolt and loosen the the other.
Old Mar 31, 2005 | 08:31 PM
javieljb's Avatar
javieljb
The bumper didn't need to be removed for this Ranch Hand. Just the tow hooks.
Old Apr 1, 2005 | 12:37 AM
exiled's Avatar
exiled
all you should have to remove is the towhooks. make sure you dont lose the bootstrap that is inside the framerail it'll be a bugger to line it back up.. i just a short piece of stiff wire to keep it lind up untell i got the mounting brackets and towhooks started... i got a pic of mine in my gallery...
Old Apr 1, 2005 | 12:43 AM
exiled's Avatar
exiled
that ranchhand doesnt look like a knockdown type do you not have trouble raising your hood i thought this body styles had to have a knockdown type hence why i got a knock down instead making my own......but any how thats a tough looking guard to say the least.....
Old Apr 1, 2005 | 07:52 AM
czcwest's Avatar
czcwest
Question
Okay. I was looking at my tow hooks and the bolts go up into the frame. I can't see anywhere except the front (behind the bumper) to get in there where the bolts are . A little more guidance here please guys. I just don't see how I can unbolt the tow hooks without loosing the nut in the frame. Thanks
Old Apr 1, 2005 | 07:58 AM
kingfish51's Avatar
kingfish51
There is a captured plate inside the frame that the tow hooks bolt to. If you look at the tow hook you will see two holes for the bolts. One is just a regular hole, the other is elongated and widened. Remove the bolt in the regular hole, and loosen the bolt in the elongated hole. You can now remove the tow hook and not lose the captured nut plate.
Old Apr 1, 2005 | 08:05 AM
czcwest's Avatar
czcwest
Thumbs up
Ahhh! Now I see what you have all been trying to tell me. Sorry guys a little slow. Just remove the front bolt and loosen the rear. Thanks for the quick replies.
Old Apr 1, 2005 | 09:26 AM
javieljb's Avatar
javieljb
I have no issues opening the hood. I stick my hand in the middle of the grille to unlatch it, then pull straight up. It clears the guard by about an inch or two. Those Ranch Hand guys really know how to make the guards. I can take a picture or two of the clearance if anyone is interested.
Old Apr 3, 2005 | 09:51 PM
exiled's Avatar
exiled
yup that ranch hand guard really looks good. when i was hunting up a guard for my fx4 all i found was knockdown kind i just thought you had to have them...i like the grill guard on that ranch hand looks pretty beefy...
Old Apr 3, 2005 | 09:56 PM
exiled's Avatar
exiled
unless your bullbar's mounting bracket is built like the towhooks at some point you'll have to take that back bolt out just take care to keep it lined up some how. it'll save you some aggravasion... just my experence...lol
69ford99
2004 - 2008 F150
Apr 5, 2010 10:49 PM
mizzleman
1997 - 2003 F150
Mar 2, 2008 08:58 AM
bones68
Bronco II
Nov 2, 2006 03:15 PM
RRobben
1978 - 1996 Big Bronco
Jan 11, 2005 09:08 PM
calzone
Bronco II
Aug 6, 2004 04:47 PM
