horn problems
Old Mar 29, 2005 | 07:06 PM
mooreswm's Avatar
mooreswm
Question horn problems
2000 excursionanybody now an easy fix for horn works with door lock button and horn button on wheel with key off but not when the engine is running
Old Mar 29, 2005 | 09:35 PM
kranky_kel's Avatar
kranky_kel
Question
English, please
Old Mar 30, 2005 | 05:41 PM
mooreswm's Avatar
mooreswm
horn
horn only works when the key is off .
Old Sep 30, 2006 | 05:52 PM
cficare's Avatar
cficare
Did you ever find out why your horn worked only with the key off? I ask because mine just started doing the exact same thing. Engine off, horn blows ... so it's not the clock-spring ... engine running, no horn or cruise control.
Old Sep 30, 2006 | 09:16 PM
mooreswm's Avatar
mooreswm
it was related to the cruse control ford fixed it then i got a recall notice it burned out some wiring and lost the ground
Old Oct 1, 2006 | 08:23 AM
cficare's Avatar
cficare
Thanks for the reply. Guess I'll take it back and claim it doesn't work since they've done the recall work.
Old Oct 22, 2006 | 02:33 PM
X-mode's Avatar
X-mode
It's the cruise control box, on the passenger side.
I had the same problem, replaced the box, it's working like a gem.
Old Oct 22, 2006 | 04:13 PM
cficare's Avatar
cficare
The dealer replaced my GEM to get the horn working properly. If I wasn't looking at getting rid of my '01 Limited, I would've just installed air horns instead. BTW ... getting rid of the '01 because I'm in the market for an '05.
rzns60
Sep 12, 2020 12:02 PM
js74f250
May 12, 2016 04:31 PM
stang9090
Sep 24, 2015 04:00 PM
centralNH
Mar 17, 2014 08:51 PM
gangstakr
Feb 3, 2014 01:29 PM
