Dash indicators / guages wont initialize
Old Mar 24, 2005 | 12:03 PM
mikey1157's Avatar
mikey1157
I have a 2001 Expedition, every 4 or 5 times the ignition is turned, the dash won't initialize and the vehicle won't start. I give it 5 min., turn the key then everything lights up and guages sweep. Does anybody have an idea where to start looking?
Old Mar 24, 2005 | 12:05 PM
powerstroke6ltr's Avatar
powerstroke6ltr
Either the GEM Generic Electronic Module or Battery is where I'd look. First I'd look at the battery...Sounds like it needs help quick. Maybe a new one. A gauge sweep is a tell tale sign of a weakening battery. Actually I'd stay away from the gem if at all possible
Old Mar 24, 2005 | 12:41 PM
ExpyBob's Avatar
ExpyBob
I agree. This is a common symptom of a failing battery. check that first It's probably due.
Bob
Old Mar 24, 2005 | 01:28 PM
mikey1157's Avatar
mikey1157
Battery failing?
In reference to the guage sweep, fail to start symtoms I presented before, When the engine won't start, It still cranks normally and will try to start but the fuel system in't energized. Is this still an indication of a failing battery???
Old Mar 24, 2005 | 01:39 PM
EMS Guru's Avatar
EMS Guru
Have the alternator and voltage regulator checked.
Old Mar 28, 2005 | 08:00 AM
mikey1157's Avatar
mikey1157
It turned out to be a bad wire at the Ignition switch that caused all of the problems.
Thanks for the help
Richadortiz
Jan 17, 2016 05:50 AM
Goinnuts
Dec 2, 2015 03:12 AM
Joshua Paul
2004 - 2008 F150
Nov 15, 2015 01:10 PM
baldboyford
Oct 26, 2014 10:42 AM
oig2scout
Dec 6, 2009 10:47 PM
