80-86: Dim Dash Lights - Final Answer?
Old Mar 23, 2005 | 09:46 PM
84f150guy's Avatar
84f150guy
What's the final call on dim dash lights, how to resolve it so i can see without squinting what's going on, and i don't want to put in a new cluster. from reading around, there's ways to clean it off, change the bulbs, or even put in different color lights, or in some cases, diferent color leds?
what's the good word, oh mighty FTE members?
Old Mar 23, 2005 | 10:18 PM
85F_150driver's Avatar
85F_150driver
you can take the cluster out and take the blue caps off the bulbs. then if you want you can put in different colored bulbs. when i did mine i uses the regular clear bulbs except behind the speedo i put in blue bulbs it makes it the same color as befor only brighter.
Old Mar 23, 2005 | 10:30 PM
84f150guy's Avatar
84f150guy
okay, so another question. how powerful of a bulb do i use? is there anyway to change that green, to maybe white or red? is it a screen or some sort over the cluster, to change the color you see looking at the cluster?
Old Mar 23, 2005 | 11:23 PM
85F_150driver
It takes a 194 bulb i believe it is. Its the same as the marker lights in the fenders. On the inside of the cluster there is plastic domes that snap in place on the cluster then the clear bulb is inserted inside the dome thus creating the color you see now. If you remove the blue domes and replace with a 194 colored bulb it will light up in the color you put in. I think it takes like 7 or 8 bulbs total. they are hooked into the cluster with special twistie thingies, so if you lose one ur up the creek lookin in the yard for a new one. By just removeing the caps inside the cluster you will be supprized with the difference in brightness.
Old Mar 24, 2005 | 12:02 AM
84f150guy's Avatar
84f150guy
about how much did it all run you to do it yourself?
Old Mar 24, 2005 | 02:30 AM
85F_150driver
i reused all the bulbs that were already in there except for 2. One good hint on the headlight **** and windsheild wiper **** is to use a scre driver to push the tab in the **** and it should slide right off. If you need new bulbs or want a different color thats the only expense you should have. Also if you have a auto tranny then be careful with the shifter indicator.
Old Mar 24, 2005 | 07:25 PM
5_labsownus's Avatar
5_labsownus
You can get replacement LED bulbs for 194 sockets. That will make the lights brighter.
ZachWiesehan
Dec 23, 2014 10:35 AM
AllaboutMPG
Feb 1, 2012 06:53 PM
riverrat2
Jul 29, 2008 05:59 AM
Ultraute
Electrical Systems/Wiring
18
Jul 12, 2006 09:22 PM
corllrios
Nov 13, 2003 03:12 PM
