Need more help in identifying another engine.
Old Mar 22, 2005 | 10:43 AM
51PanelMan's Avatar
51PanelMan
A fellow board member turned me onto this engine. It came out of a '52 F1. The seller claims that it's a 215. He also stated that the engine belonged to a school district since being purchased new and was never replaced, but rebuilt to 0.010. The engine has a tag to support the rebuild. However, from other pictures that I've seen of '52 215s, the valve cover looks different; note the position of the oil breather.
Here's a 215 from a running '52:
Here's what's for sale:
Is the above engine a 215 or am I just being silly and over examining it?
Thanks, Ilya
Old Mar 22, 2005 | 12:04 PM
barry's Avatar
barry
My parts books (48-55) has a drawing of a 215 just like that with the same exact valve cover. It shows the oil cap farther back like that. It say "1953- 6 cyl OHV 215 CID Models J and JH" which are P series vans on F-350 or F-500 chassis. It's a 215. The conventional trucks had the cap in front and the P series had it farther back for access thru the engine cover.
Barry
50 F-1
Old Mar 22, 2005 | 12:20 PM
51PanelMan's Avatar
51PanelMan
Barry
50 F-1
Let's see if I got this correct. The engine is from a '53 P series (parcel van)? Heavier duty, maybe?
Which is the correct valve cover for a conventional truck, the one in the first picture or the one in the latter pictures?
Either way, this engine would be as correct as I can get at this time for my '52 Panel, right?
Thanks, Ilya
Old Mar 22, 2005 | 12:46 PM
barry's Avatar
barry
THe first pic has the correct valve cover for your panel truck. Only the parcel delivery series had the other cover, nothing else. P series had a different carb with the remote air cleaner. It's as close as you're gonna get right now!
Barry
Old Mar 22, 2005 | 12:50 PM
51PanelMan's Avatar
51PanelMan
Barry
Thanks. I guess I have to make arrangement to travel to SoCal to get the engine. I may know of where I can get the proper valve cover. The seller has the carb/air cleaner to go with the engine.
I have the remote air cleaner and different carb from the '52 P5 from which I pulled another inline 6 from.
Ilya
Old Mar 22, 2005 | 05:33 PM
bobj49f2's Avatar
bobj49f2
I have this engine from a '52 F-6 conventional truck. It could have replaced the original engine but this is the engine that was in the truck when I bought. In fact it's still sitting in the front frame rails. It has the oil cap toward the back.
Old Mar 22, 2005 | 06:27 PM
barry's Avatar
barry
Here's a good one for you. In 52-54 books, there was 2 covers listed, depending on the depth of the recess in the covers for the stud grommet. In 55, they replaced the 2 into one with a 55 car part number. In later years, they replaced it again with a 59 car number for both the 215 and 223. These covers were probably swapped every which way when they were replaced or rebuilt.
Barry
50 F-1
Old Mar 22, 2005 | 07:14 PM
51PanelMan's Avatar
51PanelMan
Thanks everyone, Barry and Bob especially.
Unlike U2's song, I have found what I was looking for.
Bob, we could still work something out on a trade for that '52 engine. Remember, I still have a good F2-F6 clip. You know which one.
Still waiting for the block casting number from the seller to confirm.
Ilya
Old Mar 23, 2005 | 07:10 PM
51PanelMan's Avatar
51PanelMan
The seller provided me with the following information about the engine:
Drivers side manifold casting number is EAA 9430A
Drivers side block number casting towards rear of engine EAA -6015
Is it still a '52? I think so, but would like reassurance because I have to drive south to L.A. and back home in one day. That's 10-12 hrs in the truck. I don't want to do it if it's the wrong engine.
Thanks, Ilya
Old Mar 23, 2005 | 07:41 PM
barry's Avatar
barry
The parts books don't show casting numbers, but the exact part number for the 215 exhaust manifold is EAA 9426-A, listed for 52-53.
Barry
50 F-1
51PanelMan
86
May 6, 2015 06:24 PM
fordboy_52
Kansas Chapter
Apr 14, 2008 10:12 AM
Bear River
Aerostar
21
Aug 18, 2007 11:34 AM
51dueller
16
Apr 1, 2007 12:43 AM
51PanelMan
Jul 4, 2006 09:06 PM
