4" or 5" straightpipe?
Old Mar 20, 2005 | 07:27 PM
RedDragon's Avatar
RedDragon
Is there any significant difference between putting on a 4" or 5" straightpipe w/ 4" DP. I've read other posts on the topic, and it seems the exhaust tone being a little deeper w/ 5" is about the only difference. Is it a lot deeper or about the same? I recently cutout the muffler and have it straightpiped w/ stock size. It really helps the turbo spool up faster, and it sings great. Although, it sounds terrible when the EBPV closes to warm-up and the EGT's did not drop much. Has anyone tried both 4" and 5"? If so, which did you prefer? Thanks for any info.
Old Mar 20, 2005 | 08:21 PM
mybigredford's Avatar
mybigredford
i was just wondering how bad the stock pipe sounds when the ebpv kicks in, i like the sound of it, it sounds like a jet, but i was thinking of taking the stock muffler out. so i thought i would ask you since you have yours out, what does it sound like (why it sounds terrible) does it sound like a bigger jet now???
Old Mar 20, 2005 | 08:40 PM
77hiboyboy's Avatar
77hiboyboy
sounds like a huge jet without a muffler, when it would go to hi-idle like when fueling people would look and give the thumbs up and then sshhhhhh and they would frown. I unplugged mine and couldn't be any happier.
Old Mar 20, 2005 | 08:44 PM
RedDragon's Avatar
RedDragon
Well, maybe I should rephrase that. It dosen't sound terrible, but it doesn't have that deep, mean sound that I like. Some mornings I let it idle in the parking lot at work and when the EBPV kicks in everyone that walks by stands there and stares for a minute trying to figure out what is wrong. I then have to explain the whole EBPV function and straightpipe. It's really kinda funny. Is Ford the only trucks w/ EBPV? A few guys have Dodge/Cummins and they have never heard of EBPV.
Old Mar 20, 2005 | 09:05 PM
vancouverpower's Avatar
vancouverpower
I had a 3.5" straight pipe with the stock down pipe. I just switched to a 4" d/p and 5" straight pipe. I didn't notice any cooler egt's but it looks cool! I personally think it sounds way better. Deeper throaty sound with less turbo flutter. BTW I did need to put a small dent in the 5" pipe to clear the crossmember bolts.
Old Mar 20, 2005 | 09:08 PM
barebackjake's Avatar
barebackjake
i had 4" on my truck and bigger injectors forced me to go 5 to keep egt's down and flow the air. if your gonna stay mild on the mods 4" is fine, if your thinking about injectors and a bigger turbo go 5"
sounds sweet one way or the other.
Old Mar 20, 2005 | 09:45 PM
kilapapipa's Avatar
kilapapipa
Try this, 4" turbo back, no muffler, exits in front of the rear tire. When my EBPV kicks on with high idle, you can't have a conversation within 20 feet of the outlet.
Old Mar 20, 2005 | 10:11 PM
444dieselrod's Avatar
444dieselrod
Like kilapapipa said. big pipes and the EBPV = lots of noise.
The dual fives where like that, twice, so I unplugged it.
bigger pipes will magnify any sound except the turbo flutter, maybe its just cuz I have duals, but mine flutter's a whole lot less then my buddies "stock" straight exhaust.
The only restriction in my exhaust is the down pipe, after that it was 2 1/2 dual into 5" side pipes, then I had it all changed to dual three" into the side pipes, the tone got ALOT deeper, and the whistle got insane. when you rug it, it's crazy loud, i love it, but quiet inside
The jump to the three didn't realy lower EGT's, but it did give me a boost in boost, only a couple of PSI and only noticeable at 100 MPH and FLOORED!!
it all depends on money, 4 or 5. do what you can afford, both will work fine.
Diesel Rod
Old Mar 21, 2005 | 01:06 PM
RickyBR's Avatar
RickyBR
I have read on here awhile ago that you don't need 5" unless your pushing 500 H.P., as a matter of fact, I think I've also read that you loose a little low end torque going from 4" to 5".
Old Mar 21, 2005 | 08:15 PM
Quadzilla's Avatar
Quadzilla
4" is all you need until you approach 450hp. A 5" system will run a little cooler, sound a little deeper, and look a whole lot better. I've gotten used to the size of my 5" system with 6" tip, but it sure draws attention at the truck stop. I can't get out of there in less than an hour, answering questions.
Click here.
Old Mar 21, 2005 | 08:21 PM
edub32's Avatar
edub32
Where do you all get your straightpipes!?? LOL Nobody here in my neck of the woods can make one. Every shop I've called can't do 4 inch piping in their mandrel and can't make straight pipes. Is the superduty exhaust straight enough to just run a pipe to the rear axle and buy a pre-bent elbow?
Old Mar 21, 2005 | 09:19 PM
vancouverpower
>Where do you all get your straightpipes!?? LOL Nobody here in my neck of the >woods can make one. Every shop I've called can't do 4 inch piping in their >mandrel and can't make straight pipes. Is the superduty exhaust straight >enough to just run a pipe to the rear axle and buy a pre-bent elbow?
Yep go to the big truck shop and look around. Well at least with a 6 speed, I haven't looked at a auto yet.
Old Mar 21, 2005 | 09:52 PM
MRBASS's Avatar
MRBASS
I have a neighbor down the road with 5" pipe and it sounds much better than any powerstroke I ever heard, ALOT deeper tone,flutter is almost not even noticable, If i had it to do over again it would be 5" from the down pipe back, Unbelievable difference in sound over the 4" for sure.
Old Mar 21, 2005 | 10:39 PM
mybigredford
well after reading your posts, i think i might take my muffler off. my stock system is still in great shape, and i love the sound of the ebpv makes, so if you guys say taking the muffler out intensifies it more than i am all for it. i dont want to spend money on a bigger exhaust system until the stock one rusts out. hehe i cant wait. i have this neighbor that is a real ********* with his truck (or should i say staightpipes), so i hope this kinda gives him a taste of his own medicine!!! i guess potatoes in his pipes didnt work, maybe if i park in front of his house and wake him up at 10PM everynight he will get the hint. wish me luck!!
Old Mar 21, 2005 | 11:14 PM
RedDragon's Avatar
RedDragon
I was thinking I would order a piece of 5" tubing and a 4"-5" adapter to go on at the DP, then exit in front of the rear tire w/ an elbow. Think that will work, and/or clear the tranny crossmember?
