4" or 5" straightpipe?
Old Mar 24, 2005 | 02:54 PM
  #31
Ggg6's Avatar
Ggg6
Here we go, I got the info.
Walker/Dynomax Aluminized steel over the axle pipe. 55102 (45° exit)
Walker/Dynomax Stainless steel over the axle pipe. 55142 (45° exit)
IMCO Aluminized steel over the axle pipe. 55014 (90° exit just like OEM)
I didn't know about the IMCO part or the W/D Stainless Steel part when I did mine, I used the 55102 on both my 96 and 2000. Both W/D pipes exit at a 45° angle behind the rear wheel and need about 18" welded onto the tip to make it past the bumper/fender, otherwise it is tucked under the truck a little. I left it short on my 96 and there was only a little soot on the chrome bumper. On my 2000 I welded the extension on and no soot at all on the bumper. I have had the 4" on the 96 for at least 4 years and no rust at all, so I see no reason to go S/S unless you just want the look. The IMCO 55014 exits in stock location(90° relative to the fender) behind rear wheel. To find a IMCO dealer near you click here http://www.imcoweb.com/index2.html
Old Mar 24, 2005 | 04:23 PM
  #32
afinepoint's Avatar
afinepoint
Originally Posted by vancouverpower
I can't imagine that dumping the exhaust in front of the tire will wear it out faster. I can hold my hand on the tail pipe without burning it so it's not that hot. No different from driving on hot asphalt. Plus some f150's exhaust dumps right there from the factory. :-)
Manufacturers do what they do to reduce costs or liability or both. It has to be more expensive to run the exhaust behind the rear vice in front. Ford won't do it without good cause. - at least in their minds.
I know here in VA the tailpipe simply has to be behind the passenger compartment.
I'm sure at any speed the heat of the exhaust is negligible. But at idle over time . . .? Perhaps it not just the heat maybe the exhaust gases attack the rubber and metal as well.
Just a fine point.
Reg
Old Mar 24, 2005 | 08:00 PM
  #33
superstrokin's Avatar
superstrokin
now I plan to run a 4" downpipe from Tymar, then go with 5" pipe back....should I go in front the tire? Right now I have it split into 2 pipe over the axel and out each side at 45 degrees. Would I be able to reuse the 2 3.5" pipes from the 5" or should I go with bigger, or like I said before, shoudl I just go easy in fron the tire with a 5"
Old Mar 24, 2005 | 09:01 PM
  #34
barebackjake's Avatar
barebackjake
ive had mine infront of the rear tire for 5 years now with no issues other than the soot on the wheel but that wipes right off when i wash the truck. look at how many class 6 and 7 trucks exaust is usually dumps out just behind the cab underneath or infront of rear axle. if your strait piping behind the wheel is gonna be less cab noise and more money. im going to run mine to the back but only because im going to 4 link the rear end and go full air ride in the back and would be nice to have a tool box under the flat bed infront of the wheel.
Old Mar 24, 2005 | 09:09 PM
  #35
superstrokin
what about on the body? A lot of soot or no? Th ecorners of my bumper are black right now from the duals
Old Mar 24, 2005 | 09:52 PM
  #36
barebackjake
ive got a flatbed on my truck and with stock injectors didnt notice any, with the ones im running now i do, but it wipes right off. ive got a turn down tip on it now which helps too
Old Mar 25, 2005 | 08:39 PM
  #37
superstrokin
hmmmmwhat about dual 5", one out each side?
Old Mar 25, 2005 | 09:01 PM
  #38
Frost13's Avatar
Frost13
that would sound COOL!
Old Mar 25, 2005 | 09:03 PM
  #39
superstrokin
I hope so!Ill have the only trruck on the block with 2 big ol 5" pipes! Has anyone ever seen this set up?
Old Mar 26, 2005 | 01:08 PM
  #40
RickyBR's Avatar
RickyBR
not dual 5", "other than stacks", but I have seen a picture of a single 6".
Old Mar 26, 2005 | 02:55 PM
  #41
superstrokin
stqacks....hmmmm did they come up through the bed or out the sides behind the cab?
Old Mar 26, 2005 | 04:15 PM
  #42
RickyBR's Avatar
RickyBR
This is what I'm talkin about when I say stacks, http://www.blackclouddiesel.com/Stacks/stacks.htm .
The picture that I saw of the 6" was coming out the passenger side in front of the drive wheel.
Old Mar 26, 2005 | 04:20 PM
  #43
superstrokin
that site goes to motor haven .com.....I did a search after yor last post and found the blackcloud site....the more i look at it, the more I want it....just makes me wonder though...with straight stacks you have ot put a can over it to keep water out tright? Thats what truckers have to do on the big rigs...or they have a flap....
Old Mar 26, 2005 | 05:36 PM
  #44
444dieselrod's Avatar
444dieselrod
My buddy drilled a tiny hole in the elbow on the bottom of the stacks, this lets all the water drain out. It will have to REALY be raining for the pipes to fill up with enough water to get to the turbo, being that it is the same height as the dash, I dont think that it will be much of a problem. but when mine go on, I will just drill the hole.
Diesel Rod
Old Mar 26, 2005 | 06:11 PM
  #45
superstrokin
ust looking at my truck.....if I use stacks I will have to come out the side of the body....I have a cowboy 1/2 sleeper that goes almos tto the front of the wheel well, I dont think stacks would fit!
