Emergency Flasher Switch
Old Mar 18, 2005 | 10:27 AM
Knight70F250's Avatar
Knight70F250
'69 F250. The emergency flasher switch has gone bad. It's under the dash on right side- sort of a toggle switch, on/off. Now my brake lights/4-ways won't work. Turn signals, running lights OK. I've replaced turn signal switch, but that didn't fix it. There's power to the emergency flasher switch, but not coming out. I need to find a new one, but it's not in the catalogs, and there's nothing this old up here in the boneyards. Can anyone steer me in the right direction to find a replacement? Maybe someone has one they could part with? (It's not the in-dash type like my '70.) Any help appreciated. Thanks.
Old Mar 18, 2005 | 11:53 AM
qman's Avatar
qman
I bought an emergency flasher for my 72 at Autozone for about $2.
Old Mar 18, 2005 | 12:12 PM
Knight70F250
Thanks for the quick response, but I need the actual Emergency Flasher Switch assembly, with the wiring attached to the back and not just the little flasher cylinder.
Old Mar 18, 2005 | 12:26 PM
jstandle's Avatar
jstandle
Ebaymotors...
Items 4535131688 and 4535928357
Old Mar 18, 2005 | 12:27 PM
jstandle's Avatar
jstandle
Is there anyway to substitute a regular toggle switch? I've never looked at one of these so I'm not sure how you could make a work around.
Old Mar 18, 2005 | 03:03 PM
Knight70F250
Thanks for those responses jstandle. That first item on ebay is just what I needed. However, I've discovered a new wrinkle. It turns out that if I hit the turn signal, and have the emergency flasher switch in on position, the 4/ways work. If I don't have the turn signal going, 4/ways don't. Still no brake lights.
Old Mar 18, 2005 | 08:48 PM
rebocardo's Avatar
rebocardo
This may be your turn signal switch that is bad. Test for power going into and out of your brake light switch. Then test for power going into and out of the turn signal for the brake wire. You have to disconnect the wires on the column for this.
Old Mar 19, 2005 | 05:32 AM
jowilker's Avatar
jowilker
Are you trying to run your 4 ways and turn signal at the same time? I don't think it's supposed to happen. They will work in an either or.
John
Old Mar 21, 2005 | 11:42 AM
Knight70F250
jowiliker: I'm not trying to run 4ways and turn signal at the same time, it's just that I discovered that the only way to run the 4ways is if the turn signal is on (either left or right-doesn't matter).
rebocardo: I'm inclined to agree with you. I have a new turn signal switch and hooked it up and had the same problem (no brake lights). I noticed that the old turn signal switch had different color wires than the ones under the dash. I assumed that the column had been changed at some point since it's not the same color as the rest of the truck and the front has disk brakes. The column wire colors on old turn signal switch are:
big connector: blue/yellow, green/white, blue/white, light blue, red/black.
little connector: orange/blue,green/brown.
The dash wire colors are:
big connector: blue/yellow, green/white, blue/white, light blue, dark green.
little connector: light green, yellow/black.
The new turn signal switch has wires the same colors as the dash wires. Would the new turn signal switch have to be mounted in the column to work properly, 'cause I hooked it up outside the column to see if it would work before I went ahead and pulled the old one? Thanks for the help and suggestions so far.
hdunlap
16
Nov 19, 2016 02:36 PM
WiBud
Dec 29, 2007 09:10 PM
mrlightrail
16
Oct 23, 2007 09:02 PM
dakonthemountain
13
Nov 26, 2005 10:13 AM
JimUT
Feb 19, 2002 06:51 AM
