Emergency Flashers, when were they standard?
Got a 68 F100, and it's got two flasher relays under the dash, 1 just hanging by the fuse box (turn signals) and another one to the right of the steering column, clipped to a little clamp under the dash. I was thinking it was for Emergency flashers, but can't find any control switch.
Any idea what this is?
hey mr. golfersa. i just bought a column out of a 76 and it has the hazzard lights switch on the column just like that one, someone had swaped it into this truck b.c of it coming out of a truck with p/s and a 4 in the floor , they did this to accomidate a b&m floor shifter. i bought this column to go in my 69 f100 power steering conversion. they say the 67-72 wiring under the dash is all the same and it should all go in with no problem. well my hazzard light switch was naturally in the glove box. my problem is brake lights and getting the hazzard lights on the column swaped from the glove box. i got turn signals though. any seggestions? thanks
When I put a 76 column in my 66, I cut the wires to the column hazard switch and bypassed them leaving the switch in the column and retaining the dash switch.
The wiring was not the same for my truck. You will need to find the horn wire, the brake light and finding the 4 corners turn signal is pretty straight forward. Use plug in connectors so that you can switch one if you need to.
Look for these, may not work for you but it could, so use as a guide only.
blue with yellow stripe = horn
red with black stripe = brake power
blue = turn signal flasher
green = right rear
yellow = left rear
John
green = right rear
yellow = left rear
John
Originally Posted by GolferSA
Is this a stock column for '67 Custom Cab? "Hazard" switch on the column?
Thanks...
Thanks...
The 1967 and non A/C 68/69 flasher switch and bracket are the same ones used in 1966 Ford passenger cars: C6AZ-13A350-D. Here again, the '66 switch is different from both 1965, and 1967.
Originally Posted by f2501967
golfersa,
i noticed a chrome hole cover, i need to find one of those cuz im removing the manual choke since i now run electronic choke, anyone know where i can find one.
374052-S or 374053-S .. Cover (there are two types, either will work).
