Offroad & 4x4
Gear Ratio & diff questions
Old Mar 17, 2005 | 12:43 PM
papaw123's Avatar
papaw123
I have a '91 F150 4x4 w/ 4.9 AOD. I have 33" tires with a mild lift. The original gear ratio is 3.09 and the 33s have killed the power. I am going to change gears and want some recommendations. This is not a daily driver but occasionally drive on the Interstate. With that in mind, do you think 3.73s are a good compromise? The 4.9 doesn't like revs over 3000. What about limited slip vs. ratcher lockers? In Tennessee, we deal with ice on the roads. I understand that a ratcher locker causes problems. What about the front diff? I would appreciate any ideas.
Old Mar 18, 2005 | 12:26 AM
justshootme84's Avatar
justshootme84
I think 3.73 gears would be fair/O.K., definitely alot better than the 3.08/3.09 stock ratio. IF you go any higher, say to 4.10's, you would need a different carrier for the front ring gear at least. I would definitely not put a locker in front on a daily driver, but a limited slip like the Trac-Lok may be O.K. That's what I'm considering on my Bronco front axle. It has the factory Traction-Lock L/S in the rear already. There's several recent posts in the forums on gear ratios. lockers, etc. if you do a search.
SANDDEMON08
6.4L Power Stroke Diesel
Oct 24, 2014 12:08 PM
|WYG|SS
27
Jun 11, 2010 01:57 PM
ILLXJ
Jan 5, 2009 09:56 PM
*70F250*
Feb 26, 2008 10:59 AM
ford78460
Jan 27, 2005 02:00 PM
