Mercury 312?
Old Mar 15, 2005 | 08:16 PM
captradiator's Avatar
captradiator
Mercury 312?
A friend has what he says is a 1957 Mercury 312 that I want to obtain for my '56 F-350, says it's painted a light green. Any of you have any info on this particular motor and whether it's basically the same as the T-Bird 312? I hope to look at it in the next few days.
Old Mar 16, 2005 | 04:37 PM
RCA78SS's Avatar
RCA78SS
It should be the same basic engine as the T-Bird except for the oil pan and front cover mounts. If your truck originally had a Y-block, you can swap that stuff on to the Merc mill.
Old Mar 16, 2005 | 04:59 PM
captradiator
Thanks for the info. As soon as I can take a look at the engine, I'll let y'all know.
Old Mar 16, 2005 | 06:53 PM
46yblock's Avatar
46yblock
The block should be an ECZ-C, if it is 1957. However, that does not insure it is a 312. 57 292s were also ECZ-C. The heads should be ECZ-G for 1957, but once again they appeared on 292s as well as 272s in 1957.
Old Mar 16, 2005 | 07:09 PM
286merc's Avatar
286merc
If it is truly a 57 Merc it will be a 312, they didnt use the 292 past 55. But as often mentioned here just about any part can be swapped so you wont really know until you drop the pan and check for ECZ mains caps which were only used on the 312.
Good luck. BTW, if it happens to be a 368 Ill be glad to take it off your hands!
Old Mar 21, 2005 | 08:12 AM
azwafree's Avatar
azwafree
I have an ECZ-C in my '56. This engine is red. My plan was to paint it yellow with gray covers for kicks and to make it look more "correct".
In "Classic Pickups of the 1950's" on page 49 they illustrate a "56 yblock but the engine is red with black covers and rams head exhaust manifold. There is no cross over. Is this all wrong?
Old Mar 21, 2005 | 05:10 PM
captradiator
From what little I know, the rams head/horn manifolds were used on bigger trucks and cab-overs, but I believe they can be used on the smaller trucks.
Old Mar 21, 2005 | 06:26 PM
kb-65's Avatar
kb-65
I have a 312 that is dark green I don't know what it came out of but it had a 57 or later dist.and Intake. It is a 312 i took it apart. Some or all of it will someday be in my 57 T-bird.
Old Apr 16, 2005 | 08:38 PM
captradiator
I finally got the B-600 bus to the shop yesterday afternoon and, with the help of our forklift and the "Blue-Tongued" cutting tool, had the engine and transmission out in about four hours this morning. The block, heads and intake are dark green, and the only thing I noticed before knocking off for the day was that it used a spin-on/off oil filter, rather that the cartridge-type on the engine that's in my '56 F-350. I'll clean it and check for numbers Monday, after work, and give another report.
Johnny
Old Apr 19, 2005 | 08:25 PM
captradiator
Fellow Members,
The numbers/letters on the block are ECZ-C and the heads ECZ-G, just as stated in several of y'all's replies. The bus has been sitting for about nine years and I have NOT tried to turn it over. Should I just take it to my machine shop or try to turn it, after squirting in some Marvel Mystery Oil? Naturally, I'd like to NOT have to rebuild it, but am prepared to do so, if necessary.
Johnny
Old Apr 19, 2005 | 09:52 PM
46yblock's Avatar
46yblock
Congratulations, it is sounding more and more like a 312. My opinion is to get it rebuilt now.
Old Apr 22, 2005 | 03:52 AM
pcmenten's Avatar
pcmenten
Originally Posted by captradiator
Fellow Members,
Johnny
Yeah, I'd spray PB Blaster into the plug holes and give it some time to soak. I have a 312 crank that's covered with surface cracks and I suspect it's from letting the engine sit and then trying to start it.
Also, if you don't rebuild, you might end up with a leaking rear main seal. They dry out from sitting, then when the engine's started when the seal is dry, the seal scorches and then it leaks.
Good luck.
Old Apr 25, 2005 | 09:06 PM
286merc's Avatar
286merc
My suggestions:
1 Put PB down the holes as Paul said; just enough to soak in past the rings. You can buy PB by the gallon with a hand pump spray bottle these days.
2. Drop the pan, clean sump and oil filter screen.
3. Pull mains and rod caps one at a time and look for damage.
4. If bearings look good then pull and replace the rear seal. All 312's were rope until very recently.
5. Turn it over by hand with plugs still out.
6. New plugs, cap, rotor, condenser and wires.
7. Fire in the hole.
The above takes very little time and money. Y's have a long history of coming to life after decades of sitting. Often times the only shop work that needs doing is rebuilding the rocker assemblies; many Y's were junked when oil passages plugged up.
gusso
Feb 13, 2015 07:31 AM
tbugher62
Jan 1, 2015 06:54 AM
gysgtbigdaddy
Aug 22, 2014 08:13 PM
capelo
23
Apr 15, 2014 04:21 PM
Nathan
Jun 5, 2000 07:59 AM
