1976 C6 missing gear
Old Mar 14, 2005 | 09:43 PM
o'berry farms's Avatar
o'berry farms
I have a 1976 F150 with a 390 and it has a C6. Last Friday the 11th i was on my way home from school in the after noon and i didn't have 2nd gear and i had it that morning and it WAS NOT low on fluid. I do try to keep up with this truck. i check m=my fluids bout 4 times a month if i get chance. So that i know the consumption rate, which is next to none. I changed the filter on Sunday and it made no diffrence. What could be wrong I also have a new moldulator valve if the will help. please help me I really like this truck and dont want to get ride of it if you have any ideas please let me know thatnk you.
George
Old Mar 14, 2005 | 10:25 PM
elginitis's Avatar
elginitis
try the mod
Old Mar 15, 2005 | 05:56 AM
stuart1's Avatar
stuart1
Was there any junk in there when you pulled the pan?
You can try adjusting the band.
It is on the left side of the transmission.
Loosen the lock nut.
Torque the adjuster to 10' lbs. and back it off 1 1/2 turns.
Hold the adjuster and tighten the lock nut.
If you have to turn it in more than 3 turns the lining is probably toasted.
There is a "snap in" replacement available.
This requires removal of the valve body.
Old Mar 15, 2005 | 01:46 PM
o'berry farms
there was no junk in the pan there was only a spec here or there nothing out of the normal. i will try that this weekend thatnk you
Mike George
May 4, 2015 04:58 PM
76f350spercamprspeal
Picture competitions
Apr 29, 2010 12:27 PM
joe f350
46
Apr 25, 2009 10:39 AM
Knucklebuster
21
Jan 12, 2008 07:33 PM
86Bronco351
1978 - 1996 Big Bronco
Sep 3, 2003 12:14 AM
