1950 2 speed axle speedometer
Old Feb 15, 2015 | 05:07 PM
Mike George's Avatar
Mike George
I have a 1950 F6 with the Eaton 2 speed axle. The vacuum diaphragm for the speedometer gear adapter is split. Is this part available anywhere? Everything else works and I would like to get the speedometer working correctly.
Thank you for any help,
Mike George
Old Feb 15, 2015 | 05:42 PM
Grey Beard's Avatar
Grey Beard
Best bet, Chuck's Trucks in CT.
He seems to have all the odd parts I needed.
Old Feb 15, 2015 | 06:19 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Yes, try calling Chuck Mantiglia of Chuck's Trucks. 203-288-2769
Old Apr 22, 2015 | 06:51 PM
56exp's Avatar
56exp
56 exp , if you are asking about the part that adapts to the speedo then the speedo cable attaches to ,Rustic Auto (518-643-8839) has one on a 56 f600
Old Apr 22, 2015 | 09:14 PM
Mixer man's Avatar
Mixer man
If mine ever goes out I think I'll make one out of thin rubber gasket material.
Old Apr 23, 2015 | 12:10 AM
CaptPayne's Avatar
CaptPayne
Mike,
I'm parting out a 52 M6 with the 2 speed rear. I was wondering what the vacuum was all about. I'll take a look tomorrow and see what sort of condition the diaphragm is in if you want?
Old Apr 23, 2015 | 07:28 PM
Mike George
Thank you for all of the help. Chuck's Trucks had a NOS speedometer part I purchased and it is working fine.
CaptPayne: If your 2 speed axle is vacuum shifted, meaning it has a large vacuum diaphragm on the axle with a spring on the rear of it, and it is in good shape, I would be interested in purchasing it. Being a '52, I think it will be vacuum operated. The other vacuum operated item is a small transmission on the speedometer that changes the ratio when you shift the axle. That is the part I found at Chuck's Trucks.
Old Apr 23, 2015 | 08:12 PM
CaptPayne's Avatar
CaptPayne
Mike,
It is the vacuum shift. Haven't gotten the rear axle out yet, but it's there under the Anthony dump hoist. Like I said I'll take a closer look at the works and let you know.
Not using either as my main project is a 51 F5 M-H, I have the whole vacuum manifold off the firewall too. I'll take a pic when I get home. Everything is in good shape iirc.
Old Apr 24, 2015 | 05:49 AM
Mike George
CaptPayne: I may be interested in more parts of your truck. Could you contact me off-forum at mike.george@hotmail.com?
Old May 2, 2015 | 09:02 PM
Sportster.Mark's Avatar
Sportster.Mark
I have a vacuum operated 2 speed rear in my 1950 F6 that I am changing out, if interested let me know. Where are you?
Old May 4, 2015 | 12:26 PM
Mike George
Sportster.Mark: I live in SE TN. If it is in good shape, I would definitely be interested in the vacuum diaphragm for the axle, maybe even the whole axle. Please contact me at the e-mail address above.
Old May 4, 2015 | 04:58 PM
Sportster.Mark
E-mail sent
WQ59B
1947 and Older Ford Trucks
May 13, 2017 08:37 PM
fordinmudd
Sep 29, 2010 06:08 PM
3414
Mar 31, 2009 09:18 AM
cana55
Jan 2, 2008 05:44 AM
Wishbone
Jan 28, 2003 08:23 AM
