brake trouble
Old Mar 14, 2005 | 04:56 PM
bayoubandit's Avatar
bayoubandit
brake trouble
i have a 92 f350 brakes have been re placed the fronts dont seem to be holding very much and the rears seem to be locking up....the brake light and the rabs light are both on,the pedal goes almost to the floor!!!any ideas?
Old Mar 14, 2005 | 07:48 PM
trike1946's Avatar
trike1946
Did you just do pads and shoes or rotor and drum cut too? I assume you have disk and drum. Do you have any leaks? Are the rear adjusted right? Is the master cylinder good? How about the distribution box?
Old Mar 14, 2005 | 07:52 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
check out the" bad brakes " forum I had simular problems with a 92 at work. this might give you some ideas
Old Mar 15, 2005 | 08:20 PM
bayoubandit
yes its disk front drums rear i dont know what all they did to it i haent had the truck very long but i know the just had brake work done on it and thats about it
Old Mar 15, 2005 | 08:51 PM
PLC7.3's Avatar
PLC7.3
bayoubandit I am sending you another email... got the year ok.
Old Mar 16, 2005 | 02:13 AM
TOM DUALLY's Avatar
TOM DUALLY
I had the same problem, had to replace the 'ABS CONTROL MODULE'. It is located inside the frame almost directly below the master cylinder. Somehow it leaks internally to a bypass circut and reduces the pressure going to the wheel cylinders.
Mike8623
Sep 14, 2010 06:48 PM
tdon11
Apr 29, 2009 07:50 PM
64fordf100292
15
Dec 12, 2007 12:02 AM
jocasseesam
May 9, 2006 12:56 PM
brokeneck
Sep 28, 2003 02:32 AM
