Why does my 69 f250
Old Mar 13, 2005 | 10:01 AM
Frank Lopez's Avatar
Frank Lopez
Why does my 69 f250
I recently acquired a 69 f250 and wondering why I have 8 lugs. It has a 360 w auto (C6 ) transmission and will start in gear?
Old Mar 13, 2005 | 10:16 AM
460 Crew's Avatar
460 Crew
All 250's have 8 lugs and as far as your truck starting in gear either someone really messed with the wiring or your neutral safety switch is messed up. The switch is in the lower end of the steering column twards the floor on the topside. It is engauged by a flipper that is connected to shifter running through the column then once outside the firewall connects to the tranny linkage rod. Also make sure you have all the selections on your shifter such as Park reverse neutral drive 2nd and 1st maybe the linkage outside is one off or somethin. Good luck their fun to work on its just trial and error.
Old Mar 13, 2005 | 10:17 AM
jowilker's Avatar
jowilker
Frank The F250 & 350 series truck are heavy duty use trucks and have larger everything under the chassis, axles, brakes, etc. including 8 lug wheels. The F100/150 trucks have 5 lug wheels and lesser sized axles & brakes.
The truck starts in drive because the Netural safety switch is compremised, either bypassed or defeted. I choose not to run one on my truck so as long as you are aware that it will start in gear you can live with it. The switch is located on top of the column about 8" up from the firewall. It looks like a gear selector, and works off the column shifter. It also operates backup lights on the trucks that have them.
hope this helps a little.
John
Old Mar 13, 2005 | 08:54 PM
Frank Lopez
Thanks for the info. 460 Crew & jowilker, I removed the switch, tested (with ohm meter) and it tested good. I was able to adjust the switch with bracket and get my reverse lights to work but still starts in gear. I guess I need to trace where it connects, thanks again.
69issofine
Jan 27, 2015 05:51 PM
brider
Aug 2, 2012 04:37 AM
Boyds6.9
Feb 22, 2006 07:24 PM
tnt35
Dec 19, 2003 02:11 AM
69man
Feb 12, 2001 11:33 AM
