F250 GVWR differences
Old Jul 30, 2012 | 08:08 AM
brider's Avatar
brider
My '69 F250 has a 300-six and a 7500 GVWR.
My "new" '69 CS has a 360 C6 and a 6900 GVWR.
What might the differences be to rate the trucks differently? The only thing I can imagine is the rear SPRINGS, since every aspect of the '69 is "better" than the '66 ('66 is manual steering, manual brakes with drums all around, '69 has PS/PB, discs up front), yet the rating is lower.
The axles are both Dana 60, '66 has 4.11 open, '69 has 3.54 LS.
Why would a CS have such a low GVWR?
Old Jul 30, 2012 | 11:16 AM
jowilker's Avatar
jowilker
Number Dummy will have a scripted answer, but I suspect it has to do with the springs.
I'm confused where did 66 come from?
John
Old Jul 30, 2012 | 08:54 PM
brider's Avatar
brider
Error in original post...
I said my '69 has a 300 six; I meant my '66 has a 300 six...
Old Jul 31, 2012 | 12:18 AM
Big_Foot's Avatar
Big_Foot
Must be the springs, my '69 CS 390, C6, dana 60 with 3.73's is rated at 7500lbs gvrw
Old Jul 31, 2012 | 12:18 PM
BradyCouchman's Avatar
BradyCouchman
my guess would be the trans and the rear end gear ratio have something to do with it also. the 4 sp will likely have a VERY low first gear and the 4.11 will make it even lower.
Old Jul 31, 2012 | 04:19 PM
jowilker's Avatar
jowilker
Gear ratios have nothing to do with GVWR.
John
Old Jul 31, 2012 | 06:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Right you are, it's all about springs. Trans and rear axle have nothing to do with it.
There are SIX different front coil springs with their specific loadrates listed for 1967/69 F250 2WD's. THREE different rear leaf springs with their specific loadrates listed for 1968/69 F250 2WD's.
Three GVW(R)'s based on what the 1969 F250 2WD's MODEL code is: 6,100, 6,900, 7,500 lbs.
Old Aug 1, 2012 | 04:17 AM
jowilker's Avatar
jowilker
Big thing is that the 7500 will beat the snot out of you and chatter your teeth while riding around in it.
John
Old Aug 1, 2012 | 10:17 PM
brider's Avatar
brider
John
I might've thought so, too, but I've been riding around in my '66 for 7 years, many times lightly loaded, and it doesn't seem harsh at all.
So I'm concerned now about my '69, which I intended to replace my '66. I've loaded the '66 with near 3,000 lbs of gravel/rock before, and regularly a full bed of green hardwood. Never bottomed the springs out or got into an "***-draggin" condition. I'm afraid the '69 at 6,900 GVWR is going to be kinda spongy; I suppose some overload leafs is the most straightforward solution?
I don't know...the '69 was kind of impulsive, the '66 really suits my needs more.
I guess the '69 CS would have a softer spring rate because a camper isn't really that heavy, and you'd want a nicer ride?
Thanks all, no more info needed here.
Old Aug 2, 2012 | 04:37 AM
jowilker's Avatar
jowilker
Give it a test drive, it shouldn't take very long to determine if the ride is acceptable or not.
John
hogfmr88
Dec 22, 2013 03:47 PM
rattosh51
Oct 24, 2007 09:50 AM
Scifi266
Sep 10, 2007 07:38 AM
ultrafast97
Dec 14, 2003 05:22 PM
69crewcab
Mar 26, 2002 06:30 PM
