clarification
Old Jan 19, 2001 | 04:41 PM
69man's Avatar
69man
clarification
I have a Dana 60 on my truck (a '69 f-250) is this Dana 60 a limited slip differential?
still trying to learn.
thanks
69man
Old Jan 19, 2001 | 07:19 PM
alpo23's Avatar
alpo23
clarification
What is the axle code on your VIN tage? If it is a 4x2 truck the axle code should have a B4 or B5 for a 4:10 or 4:56 with Limited slip rear. The code will read B4F or something like that for a 4x4. You could always crawl underneath and look for the axle code tag located on the rear axle under one of the diferential cover bolts. It should read 4.10L or actually read limited-slip some where on the tag. I'm not positive about it reading 'Limited slip' but somewhere in the dark corners of my mind I seem to remember seeing that once. The 4.10L is something I've seen. A non-limited slip will simply say 4.10.
Good luck
Eric
Proud owner of a '73 F-250 4x4 High Boy, 460 V8, NP435, NP205
And a '68 Bronco 289 v8 , NP435 , Dana 20
Old Jan 19, 2001 | 08:04 PM
69man's Avatar
69man
clarification
well unfortunatly my truck is not close to me right now. but i know that last time I checked the tag it said it was a 3.50 gear back there not a 4.10. it is a 4x2 i wish i had the numbers. sorry
69man
Old Jan 19, 2001 | 08:25 PM
alpo23's Avatar
alpo23
clarification
Your VIN tag should read C7 for the axle code if it is a limited slip. It will say 37 if it is just an open rear end. Good luck.
Eric
Old Jan 19, 2001 | 10:05 PM
69man's Avatar
69man
clarification
thanks for all you help
69man
Old Feb 11, 2001 | 03:08 PM
69man's Avatar
69man
clarification
>It will say 37 if
>it is just an open
>Eric
>NP435, NP205
>, NP435 , Dana 20
I came home this weekend finally and looked at the tag on the Rear end and the numbers say C9TADS (the D could also be and O or 0) i would like to know if this is limited slip or what it exactally is. it also says it is a 3.54. thanks
69man
Old Feb 11, 2001 | 05:22 PM
Ratsmoker's Avatar
Ratsmoker
clarification
I have always found it preferable to getting in my truck, put it in drive and mash the gas and count the number of tire marks on the road. Unfortunately right now I only leave one. But I can't help you with the numbers to tell what it is. The tag on your door should give you an axle code.
Old Feb 12, 2001 | 04:34 AM
StockMan's Avatar
StockMan
clarification
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
The "C9TA-DS" is a Dana (Spicer) 60 with, indeed, the 3.54 ratio *and* a locking differential. Your door tag should have the C7 code as Eric mentioned, assuming this is the original unit installed at the factory. You lucky dog, you! :P[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/registrysig.gif]
Old Feb 12, 2001 | 11:14 AM
69man's Avatar
69man
clarification
I checked the door tag and it does read C7. Thanks for all your help with the question.
yeah for me. =)
69man
Old Feb 12, 2001 | 11:33 AM
rc351w's Avatar
rc351w
clarification
gtex
Jan 25, 2006 09:19 PM
Manitoulin
Aug 27, 2004 07:57 PM
V10man
Nov 26, 2002 01:38 AM
69man
Aug 26, 2000 01:45 PM
