48 f1 speedometer ?
Old Mar 10, 2005 | 09:27 PM
g84t8f1's Avatar
g84t8f1
48 f1 speedometer ?
I have a speedometer out of a 1950 f6. It has the 1st;2nd,and3rd gear shift points on the face of it. I have not seen any like it anywhere.Iwould like to put it in my 48 f1.is there a place that reworks your old speedometer and gauges at a afordable price? I also am still looking for a GM power steering box with 4 1/2 turns full left to right and a 5 to 5 1/2"pitman arm. Any help would be appreciated. THANKS ART
Old Mar 11, 2005 | 12:42 AM
Earl's Avatar
Earl
Art,
Check with Barry Clussy (barry on FTE). I think he can help you out.
Old Mar 11, 2005 | 06:07 AM
g84t8f1's Avatar
g84t8f1
Thanks
George THANKS for the info. looks like you come along way with earl. keep up the good work. I guess i should post some pics later on. I already have installed a 351cand tranny.Iput the f6 cab on becuse it only had 1 rust spot on the whole cab. that saves a lot of work.the f1had some rust on the floors that someone had bolted patchs over.they also had **** carpet over the entire inside of the truck.tall about a nightmare to clean off.will post pics later. THANKS ART
Old Mar 11, 2005 | 06:19 AM
barry's Avatar
barry
George is referring to me. I may have several speedos like that here. I take yours as a core to keep my supply of repair parts going. Click on my name and send me a private message. I'll look to see what I've got. If yours is decent, I may be able to get it working again.
Barry
Old Mar 11, 2005 | 04:28 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
I know the F3 trucks had the shift points as mine has them. I noticed the same year F1 does not. ANybody here with anf F2 that can fill in the gap for us?
Old Mar 11, 2005 | 06:24 PM
barry's Avatar
barry
There's been some debate on that. All 3 of my different parts books I have list 7RC 17255-A as the only speedo head for F-1 thru F-9 for 48-50. I've parted 6 or so trucks and I've found the ones with the shift marks in F-2 and up. Never in an F-1. What complicates matters is there were 3 different manufacturer's of the heads, and no parts interchange. There was S-W, King Seeley and one other. Even the face is slightly different on all 3.
Barry
50 F-1
Old Mar 11, 2005 | 06:34 PM
Christopher2
Veteran: Navy
I have both is there anything I can do to help you ID the setup with the shift points?
Old Mar 11, 2005 | 06:45 PM
bobj49f2's Avatar
bobj49f2
My '49 F-2 has the plain speedo, no shift indicator.
Old Mar 11, 2005 | 08:13 PM
barry's Avatar
barry
I told you I would start something.................
Barry
50 F-1
Old Mar 11, 2005 | 08:15 PM
Earl's Avatar
Earl
Always causing trouble, aren't you Barry?
Old Mar 11, 2005 | 08:18 PM
g84t8f1's Avatar
g84t8f1
I have both speedometers .the one out of my f1 cab is plain while the one with shift points came out of a f6 I bought for the cab.I might even put in a aftermarket one.right now it is just trying to decide what we want.
Old Mar 11, 2005 | 08:33 PM
barry's Avatar
barry
Ain't I a stinker????????????
Barry
50 F-1
Old Mar 12, 2005 | 11:36 AM
reamer's Avatar
reamer
I just found 2 Clusters in a Bone yard with the "shift Indication" on the face.
Look around, believe it or not, they are still out there!
P.S. All the guages still work!
4tl8ford
Mar 7, 2014 09:48 PM
littsen1
Nov 1, 2013 05:27 PM
brokedown48
Jul 18, 2013 12:30 AM
phyrphighter
Sep 27, 2007 08:35 AM
hansosc
Sep 11, 2007 06:28 AM
