Speedo Compatability
Old Feb 26, 2014 | 08:07 AM
4tl8ford's Avatar
4tl8ford
I need someone who has access to a 1970 Ford Mustang speedometer and or speedometer cable with the threaded connection at the back of the speedo that fits the 4 spd Toploader used in the 302/351 V8
The Trans is identified as a RUG AV - You must also have access to a 48-52 F1 - F3 speedometer/speedometer cable
Here is what I need to find out - Will the speedometer cable from the above 70 mustang screw into the back of the F1 - F3 speedometer or will the speedometer cable from the F1 - F3 screw into the back of the Mustang speedometer
There are two connections for the 70 stang speedo - one is the screw on, the other is a plastic snap on - I need the screw on
Confusing? - It's got my stuff wrapped around the driveshaft.
A few more bits of info - The trans end of the Mustans cable is the push-in style with the metal hold down clamp
The mustang cable attaches to the passenger side ot the trans tailshaft
The speedo cable must not be for the overdrive trans nor should be for the 351 4v
or samething only different
Old Feb 26, 2014 | 02:35 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The speedo cable on 69-70 mustangs does NOT screw onto the speedo, it is a plastic collar that pushes onto the smooth nipple on the back of the speedo. I have three of these and know first hand.
See picture in link
Mustang Speedometer Cable 4Spd Concourse Correct 1969-1972 | CJ Pony Parts
The '68 and earlier uses the screw-on style from everything I remember or have seen but the '70 dash is the same style speedo as the '69. I never have seen a screw-on one past '68 that was stock.
Old Feb 26, 2014 | 02:42 PM
4tl8ford's Avatar
4tl8ford
See picture in link
Thanks for the reply - I've found references to three different cables/connections for the 70 Mustang 302/351 - Two vague screw on and mostly the push on style
I'll try and expand my search parameters
Thanks
Old Feb 26, 2014 | 04:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
There are plenty of places that can make whatever cable you need, for instance:
speedometer cable-custom built speedometer cables
Old Feb 27, 2014 | 08:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F = Parts Catalog symbol for Mustang.
Old Feb 28, 2014 | 08:01 AM
4tl8ford's Avatar
4tl8ford
Thanks Bill
Old Feb 28, 2014 | 11:05 AM
52 Merc's Avatar
52 Merc
Dick, I don't know if this will help you or not, but this guy on ebay has a speedo cable with the screw on speedo end and the push in trans end. Take a look and see what you think. It might give you some ideas.
http://www.ebay.com/itm/60-61-Ford-Galaxie-Fairlane-speedometer-cable-61-62-Truck-76-1-4-/201043717907?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2ecf23af13
Old Feb 28, 2014 | 11:31 AM
53OlderThanMe's Avatar
53OlderThanMe
I got mine from Mid Fifty that have the different size transmission side gears available based on your rear ratio.
Old Feb 28, 2014 | 04:29 PM
4tl8ford's Avatar
4tl8ford
With all the info and leads I may be able to solve my problem - I just need to determin the mininum length that is needed
Thanks to all of you guys
Old Mar 7, 2014 | 09:48 PM
4tl8ford's Avatar
4tl8ford
Thanks everyone - Going through all the information that you provided I was able to track down a speedometer cable that will work on Black Bettie - It's a 83" cable for a Fairlane - I did some swaging on the ratios and I bought a set of 4 driven gears that should be able to work to come with a best fit cable and drive
Eharang
Apr 2, 2020 05:31 PM
52 F1 Stocker
Oct 21, 2015 08:20 AM
coopdagook
Jul 31, 2011 05:33 PM
iwanaflattie
May 6, 2011 08:38 PM
shadow_almanza
Apr 24, 2010 05:58 PM
