speedometer gear question
Old Oct 28, 2013 | 08:08 AM
littsen1's Avatar
littsen1
I bought a 66 f-100 a couple of months ago. It has a 352 engine and has been up-dated with a C6 trans. The speedometer didn't work when I bought the truck (broken cable) I replaced the cable and the speedometer works fine but reads very slow. 35 mph is more like 65 mph. The truck has a 2:75 rear gear, and a tan, or possibly white speedometer gear. Any suggestions on a gear that would get me closer to the actual mph?
Old Oct 28, 2013 | 04:03 PM
jowilker's Avatar
jowilker
Do you know the tooth count on your gear?
John
Old Oct 28, 2013 | 08:53 PM
littsen1's Avatar
littsen1
No, I don't know the gear count but will check it in the next couple of tays. Thanks for the reply.
Old Oct 28, 2013 | 08:55 PM
mikeb's66's Avatar
mikeb's66
Definitely need to check tooth count. That's a pretty big discrepancy though. Generally each tooth should account for 3-5 MPH difference. I believe that with what you're experiencing you need to change with a gear that has quite a few more teeth.
Old Oct 29, 2013 | 06:27 AM
jowilker's Avatar
jowilker
My thinking too Mike, about 5mph per tooth.
listen, Get a gps speedo app for your myphone and with a helper get some actual readings for comparison.
John
Old Oct 29, 2013 | 08:27 AM
littsen1's Avatar
littsen1
Thanks guys, I'll follow your suggestions.
Old Oct 30, 2013 | 11:22 AM
daveengelson's Avatar
daveengelson
Suggest contact couple supplier's and provide them the info noted in your original post; would think their tech or counter person can provide recommendation. I always contact supplier to confirm item is in stock; as probably aware, major pain in the backside having project on hold awaiting an item on 'back order'.
Old Oct 30, 2013 | 02:52 PM
Shadowrider123's Avatar
Shadowrider123
I think you need a 16 tooth gear. Make sure it is for an auto, I seem to remember there is something different about manual and auto gears but the CRS is kicking in...
Old Oct 30, 2013 | 06:50 PM
jowilker's Avatar
jowilker
I was thinking 16 as well, but when swapping has been done larger mismatches could be in the loop.
Right hand twist for the auto.
John
Old Nov 1, 2013 | 05:27 PM
66f-100's Avatar
66f-100
I wish one of the moderators would make this program a sticky. This question comes up very often.
Speedometer Calibration Program - Method 1
Zachthemoo2
Oct 2, 2014 04:42 PM
mchbts
Apr 24, 2012 08:17 AM
PetesPonies
Jun 2, 2010 11:04 PM
TXDod65
Apr 19, 2006 11:26 AM
Andysutt
Feb 17, 2004 09:44 AM
