need motor info!!!!
Old Mar 7, 2005 | 11:18 PM
oilfieldtrash's Avatar
oilfieldtrash
Question need motor info!!!!
what size motor has intake manifold ford #9425-k 2barrel
Old Mar 8, 2005 | 12:06 AM
arcticoffroadingfish's Avatar
9425: indicates that the part is an intake manifold.
K:indicates that it is the 11th revision of the manifold since it was released.
To further narrow down what you have, answer these questions:
is it cast iron or aluminum?
is it a single plane or a dual plane manifold?
what year that would also help?
i do know that it is a fe block
hope this helps.
Old Mar 8, 2005 | 01:01 AM
oilfieldtrash
thank you artickfish im sure its cast its in a 69 f1oo rumor has it came out of a bus possible firing order 15428673 sighned still confused
Old Mar 8, 2005 | 10:15 PM
are you sure that the firing order isnt 15426378 because from what i can find and what you said it coming out of a bus it appears to be a 391 fe to be possitive about this could you tell be if there are vertical castings on the side of the block also they have a steel crank that is huge it requires a lot of machining to fit a standard dampener but i honestly beleive it to be a 391.
Adam0331
28
May 17, 2009 09:25 PM
Rosati
Feb 15, 2002 01:37 PM
BB
Jan 26, 2002 09:15 AM
dave460
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Aug 4, 2001 09:14 AM
karljay
15
Jun 10, 2001 09:54 PM
